Home » Eclipse Projects » EclipseLink » dbws response type
dbws response type [message #643108] Sat, 04 December 2010 09:59 Go to next message
trekan  is currently offline trekan
I want to expose pl/sql procedures as web service. I use dbws-builder but I can't configure strict response types only the simple xml format. If I set custom response type it won't be defined in the schema. Can dbws discover out and in/out parameters or only in ones? (in/out params don't mapped in the request neither) How can I use response types (not simple format)?
Trekan
Re: dbws response type [message #643358 is a reply to message #643108] Mon, 06 December 2010 10:52 Go to previous messageGo to next message
Mike Norman is currently offline Mike Norman
Member
Trekan:
I need a little more information - can you show me what is in the DBWSB builder file as well what the pl/sql procedure looks like?
Mike Norman | Principal Software Designer
Phone: +6132884638 | Fax: +6132382818
Server Technologies | EclipseLink Product
Oracle Canada | 45 O'Connor Street, Suite 400, Ottawa, Ontario | K1P 1A4
Re: dbws response type [message #644512 is a reply to message #643358] Sun, 12 December 2010 12:08 Go to previous message
I've switched from builder script to edit dbws files manually. Now I'm understand how to change pl/sql procedure arguments in the or.xml. My next issue to make settings in the ox.xml, I hope can do it by following documentation.
Thanks Mike!
Previous Topic:LoadTimeWeaving stopped working when upgrading to Maven 3
Next Topic:JPA 2, problem with ORDER BY AVG
Current Time: Wed May 22 15:40:37 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
