| Comment char improvements [message #644275] |
Fri, 10 December 2010 05:40  |
Marius Cojocaru Messages: 8 Registered: November 2010 |
Junior Member |
I write an editor for a language who has a different comment char then '#'.
The way is implemented now in the dltk core classes, makes difficult to change this.
Example
ScriptSourceViewerConfiguration has a nice method getCommentPrefix, and is easy to override, since anyway every language will define a class that extends this
class ScriptCommentScanner has a deprecated method getCommentChar that is still used, so I have to create a class that extends the ScriptCommentScanner, and override the getCommentChar.
worse class TodoTaskBuildParticipant in findCommentStart use hard coded the # so I have again to override this and copy the exact functionality of the upper class and change the comment char.
Can you please add a single place where the comment char is defined ( maybe TextTools).
[Updated on: Fri, 10 December 2010 06:25] Report message to a moderator
| Re: Comment char improvements [message #644500 is a reply to message #644275] |
Sun, 12 December 2010 06:40  |
Alex Panchenko Messages: 332 Registered: July 2009 |
Hi Marius,
You are right those methods can be improved.
Thank you for reporting this.
I want to make some other improvements in ScriptSourceViewerConfiguration and I'll look at methods dealing with comments as well.
Please stay tuned.
Alex
FUDForum. Page generated in 0.01501 seconds
