| LoadTimeWeaving stopped working when upgrading to Maven 3 [message #644471] |
Sat, 11 December 2010 13:42 |
Jo Grimstad Messages: 2 Registered: December 2010 |
Junior Member |
I have been using EclipseLink 2.0.1, Spring 3, and Maven 2.2.1 for some time now, working fine with load-time weaving switched on (using spring-instrument-3.0.5.RELEASE.jar).
However, I recently upgraded to Maven 3.0.1, and then things stopped working ( when executing mvn jetty:run):
ClassLoader [org.eclipse.jetty.webapp.WebAppClassLoader] does NOT provide an 'addTransformer(ClassFileTransformer)' method
This is the same message as I got with Maven 2.2.1 before having run the following setting:
export MAVEN_OPTS="-javaagent:/path/to/.m2/repository/org/springframework/spring-instrument/3.0.5.RELEASE/spring-instrument-3.0.5.RELEASE.jar"
However, with Maven 3, it does not seem as if the javaagent is picked up.
So, is there a known problem that EclipseLink stops working when upgrading to Maven 3?
FUDForum. Page generated in 0.01513 seconds
