Home » Eclipse Projects » GEF » Capture key state when tool is selected in Palette?
Capture key state when tool is selected in Palette? [message #644452] Sat, 11 December 2010 10:52 Go to next message
h1055071 is currently offline h1055071
Is there any way to query whether the Shift key is depressed when a tool
is selected in a Palette? Basically, I want to know if a key is pressed
at the point of activating the tool.
I've got a custom Tool that extends AbstractTool but can't seem to find
a way to query the key state when activate() is called on the tool.
PB
Re: Capture key state when tool is selected in Palette? [message #644464 is a reply to message #644452] Sat, 11 December 2010 12:32 Go to previous message
> PB
I did it another way. I added a listener in my GraphicalEditor:
getEditDomain().getPaletteViewer().getControl().addMouseList ener(new
MouseAdapter() {
public void mouseDown(MouseEvent e) {
EditPart ep =
getEditDomain().getPaletteViewer().findObjectAt(new Point(e.x, e.y));
if(ep != null && ep.getModel() instanceof ToolEntry) {
ToolEntry tool = (ToolEntry)ep.getModel();
if(tool != null) {
boolean shiftKey = (e.stateMask & SWT.SHIFT) != 0;
tool.setToolProperty(AbstractTool.PROPERTY_UNLOAD_WHEN_FINIS HED, !shiftKey);
Previous Topic:Problem with TextFlow clipping text on Zoom
Next Topic:draw2d interaction sequence
Current Time: Fri May 24 09:51:22 EDT 2013
Powered by FUDForum. Page generated in 0.01561 seconds
