Home » Language IDEs » PDT » Syntax Coloring (PDT)
Syntax Coloring (PDT) [message #644270] Fri, 10 December 2010 05:29 Go to next message
Ted  is currently offline Ted
I'm trying to modify the syntax colouring in my Eclipse environment but it seems to just ignore the changes I make.
I'm a bit confused about what colours are being used too. The settings in the preferences don't quite correspond to what I see when I open a PHP file.
If anyone can shed any light I'd appreciate it as I'm a bit confused!
Ted
Re: Syntax Coloring (PDT) [message #645665 is a reply to message #644270] Sun, 19 December 2010 11:35 Go to previous messageGo to next message
Mor  is currently offline Mor
same problem !
when I make the changes it's works , but after i close the editor and open again it's gone.
anyone?
[Updated on: Sun, 19 December 2010 11:40]
Report message to a moderator
Re: Syntax Coloring (PDT) [message #645673 is a reply to message #644270] Sun, 19 December 2010 13:16 Go to previous messageGo to next message
sNop is currently offline sNop
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigA44B25D9E7731CEA14094008
Content-Type: text/plain; charset=UTF-8
pls create ticket at PDT's bugtracker
On 10. 12. 2010 11:29, Ted wrote:
>=20
> I'm trying to modify the syntax colouring in my Eclipse environment but=
>=20
> I'm a bit confused about what colours are being used too. The settings =
in the preferences don't quite correspond to what I see when I open a PHP=
file.
>=20
>=20
> Ted
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk0OS+sACgkQkCAxuhXMpxXxdwCgiNHVGbPkOKNplLhY6yWL yuDk
uoYAoIqvbbMESTo1RAHVvHD4JOlb7jAn
=xFnL
-----END PGP SIGNATURE-----
--------------enigA44B25D9E7731CEA14094008--
Re: Syntax Coloring (PDT) [message #652301 is a reply to message #644270] Thu, 03 February 2011 09:14 Go to previous message
moleculezz is currently offline moleculezz
I have created a syntax color file for eclipse PDT which is based on zenburn color scheme. You can check it out here: https://github.com/moleculezz/eclipse-zenburn
Previous Topic:Running PHP Code within Eclipse
Next Topic:Opening and Saving Files Over FTP/SFTP/SSH Connection from Eclipse
Current Time: Thu May 23 02:27:26 EDT 2013
Powered by FUDForum. Page generated in 0.01636 seconds
