Home » Eclipse Projects » Mylyn » Trac Timing and Estimation Plugin mylyn integration
Trac Timing and Estimation Plugin mylyn integration [message #70191] Sat, 04 July 2009 19:16 Go to next message
phil is currently offline phil
Yesterday I installed mylyn and was blown away. However, what I found to
be lacking was integration with the Trac Timing and Estimation Plugin so
that time tracking happens automatically when a task is de/activated.
Today I started working on a patch for the e_3_3_m_3_x branch and to my
surprise it works. I'm pretty sure my design is ugly as hell, but I don't
have time to dig in right now and do it properly. What I did:
* added a totalhours field and setters/getters to AbstractTask
* when the tooltips are generated in TaskListToolTip I just return the
time stored in AbstractTask if there's any and the standard
TaskActivityManager().getElapsedTime() otherwise
* in TaskActivityManager.de/activateTask() I call a chain of functions
ultimately leading to TracXmlRpcClient.de/activateTask() where a XML-RPC
request is sent to Trac
* in TaskActivityMonitor.stop() i deactivate the currently active task so
that Trac doesn't continue counting the time if somebody forgets to
deactivate the active task before quitting
It's not perfect but it works. The elapsed time stored in Trac is only
visible after a refresh and isn't stored locally. Here's the patch:
### Eclipse Workspace Patch 1.0
#P org.eclipse.mylyn.trac.core
Index:
src/org/eclipse/mylyn/internal/trac/core/client/AbstractTrac Client.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.trac.core /src/org/eclipse/mylyn/internal/trac/core/client/AbstractTra cClient.java,v
retrieving revision 1.9
diff -u -r1.9 AbstractTracClient.java
src/org/eclipse/mylyn/internal/trac/core/client/AbstractTrac Client.java 22
Jun 2009 02:00:53 -0000 1.9
src/org/eclipse/mylyn/internal/trac/core/client/AbstractTrac Client.java 4
Jul 2009 22:49:40 -0000
@@ -37,6 +37,7 @@
import org.eclipse.mylyn.internal.trac.core.model.TracTicketStatus;
import org.eclipse.mylyn.internal.trac.core.model.TracTicketType;
import org.eclipse.mylyn.internal.trac.core.model.TracVersion;
+import org.eclipse.mylyn.tasks.core.ITask;
* @author Steffen Pingel
@@ -232,4 +233,9 @@
return null;
+ public void activateTask(ITask task) {
+ public void deactivateTask() {
Index:
src/org/eclipse/mylyn/internal/trac/core/client/TracXmlRpcCl ient.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.trac.core /src/org/eclipse/mylyn/internal/trac/core/client/TracXmlRpcC lient.java,v
retrieving revision 1.20
diff -u -r1.20 TracXmlRpcClient.java
src/org/eclipse/mylyn/internal/trac/core/client/TracXmlRpcCl ient.java 22
Jun 2009 02:00:53 -0000 1.20
src/org/eclipse/mylyn/internal/trac/core/client/TracXmlRpcCl ient.java 4
@@ -80,6 +80,7 @@
import org.eclipse.mylyn.internal.trac.core.util.TracUtil;
import org.eclipse.mylyn.internal.trac.core.util.TracXmlRpcClientRe quest;
import
org.eclipse.mylyn.internal.trac.core.util.TracHttpClientTran sportFactory.TracHttpException;
import org.eclipse.osgi.util.NLS;
@@ -1125,10 +1126,10 @@
* An InputStream of the content of the attachment
* @param replace
* whether to overwrite an existing attachment with the same
filename
- * @return The (possibly transformed) filename of the attachment. If
<code>replace</code> is <code>true</code>, the
- * returned name is always the same as the argument
<code>fileName</code>; if <code>replace</code> is
- * <code>false</code> and an attachment with name
<code>fileName</code> already exists, a number is appended
- * to the file name (before suffix) and the generated filename
of the attachment is returned.
+ * @return The (possibly transformed) filename of the attachment. If
+ * the returned name is always the same as the argument
+ * is <code>false</code> and an attachment with name
+ * appended to the file name (before suffix) and the generated
filename of the attachment is returned.
* @throws TracException
public String putWikiPageAttachmentData(String pageName, String
fileName, String description, InputStream in,
@@ -1146,4 +1147,21 @@
call(monitor, "ticket.delete", ticketId); //$NON-NLS-1$
+ @Override
+ try {
+ call(null, "worklog.startWork", Integer.parseInt(task.getTaskId()));
+ } catch (TracException e) {
+ throw new RuntimeException(e);
+ @Override
+ try {
+ call(null, "worklog.stopWork", "", 0);
\ No newline at end of file
Index: src/org/eclipse/mylyn/internal/trac/core/client/ITracClient. java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.trac.core /src/org/eclipse/mylyn/internal/trac/core/client/ITracClient .java,v
retrieving revision 1.10
diff -u -r1.10 ITracClient.java
--- src/org/eclipse/mylyn/internal/trac/core/client/ITracClient. java 20
Jun 2009 07:32:02 -0000 1.10
+++ src/org/eclipse/mylyn/internal/trac/core/client/ITracClient. java 4 Jul
2009 22:49:40 -0000
@@ -29,6 +29,7 @@
* Defines the requirements for classes that provide remote access to
Trac repositories.
@@ -209,4 +210,7 @@
void deleteTicket(int ticketId, IProgressMonitor monitor) throws
TracException;
+ public void activateTask(ITask task);
+ public void deactivateTask();
Index: src/org/eclipse/mylyn/internal/trac/core/TracTaskDataHandler .java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.trac.core /src/org/eclipse/mylyn/internal/trac/core/TracTaskDataHandle r.java,v
retrieving revision 1.73
diff -u -r1.73 TracTaskDataHandler.java
--- src/org/eclipse/mylyn/internal/trac/core/TracTaskDataHandler .java 2
Jul 2009 06:52:44 -0000 1.73
+++ src/org/eclipse/mylyn/internal/trac/core/TracTaskDataHandler .java 4
@@ -660,4 +660,31 @@
+ public void activateTask(TaskRepository repository, ITask task) {
+ if (repository == null) {
+ return;
+ ITracClient server =
connector.getClientManager().getTracClient(repository);
+ if (server == null) {
+ return;
+ server.activateTask(task);
+ public void deactivateTask(TaskRepository repository) {
+ return;
+ return;
+ server.deactivateTask();
Index: src/org/eclipse/mylyn/internal/trac/core/TracCorePlugin.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.trac.core /src/org/eclipse/mylyn/internal/trac/core/TracCorePlugin.jav a,v
retrieving revision 1.25
diff -u -r1.25 TracCorePlugin.java
--- src/org/eclipse/mylyn/internal/trac/core/TracCorePlugin.java 13 Jan
2009 07:05:20 -0000 1.25
+++ src/org/eclipse/mylyn/internal/trac/core/TracCorePlugin.java 4 Jul
2009 22:49:39 -0000
@@ -106,8 +106,8 @@
return new RepositoryStatus(IStatus.ERROR, ID_PLUGIN,
RepositoryStatus.ERROR_IO,
Messages.TracCorePlugin_Repository_URL_is_invalid, e);
} else {
- return new RepositoryStatus(IStatus.ERROR, ID_PLUGIN,
RepositoryStatus.ERROR_INTERNAL, Messages.TracCorePlugin_Unexpected_error,
- e);
+ return new RepositoryStatus(IStatus.ERROR, ID_PLUGIN,
+ Messages.TracCorePlugin_Unexpected_error, e);
Index:
src/org/eclipse/mylyn/internal/trac/core/TracRepositoryConne ctor.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.trac.core /src/org/eclipse/mylyn/internal/trac/core/TracRepositoryConn ector.java,v
retrieving revision 1.106
diff -u -r1.106 TracRepositoryConnector.java
src/org/eclipse/mylyn/internal/trac/core/TracRepositoryConne ctor.java 14
Jun 2009 23:38:26 -0000 1.106
src/org/eclipse/mylyn/internal/trac/core/TracRepositoryConne ctor.java 4
Jul 2009 22:49:39 -0000
@@ -31,6 +31,7 @@
import org.eclipse.mylyn.commons.net.AuthenticationCredentials;
import org.eclipse.mylyn.commons.net.AuthenticationType;
import org.eclipse.mylyn.commons.net.Policy;
+import org.eclipse.mylyn.internal.tasks.core.AbstractTask;
import org.eclipse.mylyn.internal.trac.core.client.AbstractWikiHand ler;
import org.eclipse.mylyn.internal.trac.core.client.ITracClient;
import org.eclipse.mylyn.internal.trac.core.client.ITracWikiClient;
@@ -652,6 +653,18 @@
task.setCompletionDate(null);
+ if (task instanceof AbstractTask) {
+ Map<String, TaskAttribute> attributes =
taskData.getRoot().getAttributes();
+ if (attributes.get("totalhours") != null) {
+ AbstractTask atask = (AbstractTask) task;
+ float totalHours =
Float.parseFloat(attributes.get("totalhours").getValue());
+ atask.setTotalTimeHours(totalHours);
task.setUrl(taskRepository.getRepositoryUrl() + ITracClient.TICKET_URL
+ taskData.getTaskId());
if (!taskData.isPartial()) {
task.setAttribute(TASK_KEY_SUPPORTS_SUBTASKS,
Boolean.toString(taskDataHandler.supportsSubtasks(taskData)) );
@@ -696,4 +709,13 @@
return new TracTaskMapper(taskData, client);
+ @Override
+ taskDataHandler.activateTask(repository, task);
+ @Override
+ taskDataHandler.deactivateTask(repository);
#P org.eclipse.mylyn.tasks.ui
Index: src/org/eclipse/mylyn/internal/tasks/ui/views/TaskListToolTi p.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.tasks.ui/ src/org/eclipse/mylyn/internal/tasks/ui/views/TaskListToolTi p.java,v
retrieving revision 1.69
diff -u -r1.69 TaskListToolTip.java
--- src/org/eclipse/mylyn/internal/tasks/ui/views/TaskListToolTi p.java 22
Jun 2009 21:19:28 -0000 1.69
+++ src/org/eclipse/mylyn/internal/tasks/ui/views/TaskListToolTi p.java 4
Jul 2009 22:49:42 -0000
@@ -183,15 +183,20 @@
for (ITask child : container.getChildren()) {
if (child instanceof AbstractTask) {
estimateTotal += ((AbstractTask) child).getEstimatedTimeHours();
- elapsedTotal +=
TasksUiPlugin.getTaskActivityManager().getElapsedTime(child,
- container.getDateRange());
+ if (((AbstractTask) child).getTotalTimeHours() > 0) {
+ elapsedTotal += (long) (((AbstractTask) child).getTotalTimeHours()
* 3600 * 1000);
+ } else {
+ elapsedTotal +=
+ container.getDateRange());
StringBuilder sb = new StringBuilder();
sb.append(NLS.bind(Messages.TaskListToolTip_Estimate, estimateTotal));
- sb.append("\n"); //$NON-NLS-1$
+ sb.append("\n");
sb.append(NLS.bind(Messages.TaskListToolTip_Elapsed,
DateUtil.getFormattedDurationShort(elapsedTotal)));
+ sb.append("\n");
return sb.toString();
} else if (element instanceof ITask) {
ITask task = (ITask) element;
@@ -204,21 +209,21 @@
String key = task.getTaskKey();
if (key != null) {
- sb.append(" "); //$NON-NLS-1$
+ sb.append(" ");
sb.append(key);
String taskKind = task.getTaskKind();
if (taskKind != null && taskKind.length() > 0 &&
!taskKind.equals(kindLabel)) {
- sb.append(" ("); //$NON-NLS-1$
+ sb.append(" (");
sb.append(taskKind);
- sb.append(") "); //$NON-NLS-1$
+ sb.append(") ");
- sb.append(", "); //$NON-NLS-1$
+ sb.append(", ");
sb.append(task.getPriority());
- sb.append(" ["); //$NON-NLS-1$
+ sb.append(" [");
sb.append(getRepositoryLabel(task.getConnectorKind(),
task.getRepositoryUrl()));
- sb.append("]"); //$NON-NLS-1$
+ sb.append("]");
+ sb.append("\n");
} else {
return null;
@@ -281,8 +286,13 @@
long elapsed =
TasksUiPlugin.getTaskActivityManager().getElapsedTime(task);
+ if (task.getTotalTimeHours() > 0) {
+ elapsed = (int) (task.getTotalTimeHours() * 3600 * 1000);
DateUtil.getFormattedDurationShort(elapsed)));
+ sb.append("\n");
Index: src/org/eclipse/mylyn/internal/tasks/ui/TaskActivityMonitor. java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.tasks.ui/ src/org/eclipse/mylyn/internal/tasks/ui/TaskActivityMonitor. java,v
retrieving revision 1.22
diff -u -r1.22 TaskActivityMonitor.java
--- src/org/eclipse/mylyn/internal/tasks/ui/TaskActivityMonitor. java 1 May
2009 22:59:22 -0000 1.22
+++ src/org/eclipse/mylyn/internal/tasks/ui/TaskActivityMonitor. java 4 Jul
2009 22:49:41 -0000
@@ -115,6 +115,7 @@
public void stop() {
+ taskActivityManager.deactivateActiveTask();
contextManager.removeActivityMetaContextListener(CONTEXT_LIS TENER);
#P org.eclipse.mylyn.tasks.core
Index: src/org/eclipse/mylyn/tasks/core/AbstractRepositoryConnector .java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.tasks.cor e/src/org/eclipse/mylyn/tasks/core/AbstractRepositoryConnect or.java,v
retrieving revision 1.114
diff -u -r1.114 AbstractRepositoryConnector.java
--- src/org/eclipse/mylyn/tasks/core/AbstractRepositoryConnector .java 17
Dec 2008 00:34:32 -0000 1.114
+++ src/org/eclipse/mylyn/tasks/core/AbstractRepositoryConnector .java 4
Jul 2009 22:49:43 -0000
@@ -29,9 +29,7 @@
* Encapsulates common operations that can be performed on a task
repository. Extend to connect with a Java API or WS
- * API for accessing the repository.
- * Only methods that take a progress monitor can do network I/O.
+ * API for accessing the repository. Only methods that take a progress
* @author Mik Kersten
* @author Rob Elves
@@ -215,9 +213,8 @@
- * Runs <code>query</code> on <code>repository</code>, results are
passed to <code>collector</code>. If a repository
- * does not return the full task data for a result, {@link
TaskData#isPartial()} will return true.
+ * Runs <code>query</code> on <code>repository</code>, results are
+ * repository does not return the full task data for a result, {@link
* <p>
* Implementors must complete executing <code>query</code> before
returning from this method.
@@ -278,4 +275,9 @@
public abstract void updateTaskFromTaskData(TaskRepository
taskRepository, ITask task, TaskData taskData);
Index: src/org/eclipse/mylyn/internal/tasks/core/TaskActivityManage r.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.tasks.cor e/src/org/eclipse/mylyn/internal/tasks/core/TaskActivityMana ger.java,v
retrieving revision 1.72
diff -u -r1.72 TaskActivityManager.java
--- src/org/eclipse/mylyn/internal/tasks/core/TaskActivityManage r.java 11
Mar 2009 00:12:44 -0000 1.72
+++ src/org/eclipse/mylyn/internal/tasks/core/TaskActivityManage r.java 4
@@ -29,6 +29,7 @@
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.mylyn.commons.core.StatusHandler;
+import org.eclipse.mylyn.tasks.core.AbstractRepositoryConnector;
import org.eclipse.mylyn.tasks.core.ITaskActivationListener;
import org.eclipse.mylyn.tasks.core.ITaskActivityListener;
@@ -103,7 +104,6 @@
* Set the first day of the week (Calendar.SUNDAY | Calendar.MONDAY)
* @see
http://en.wikipedia.org/wiki/Days_of_the_week#First_day_of_t he_week
* @param startDay
* (Calendar.SUNDAY | Calendar.MONDAY)
@@ -417,6 +417,12 @@
activeTask = task;
((AbstractTask) activeTask).setActive(true);
+ AbstractRepositoryConnector connector =
repositoryManager.getRepositoryConnector(task.getConnectorKi nd());
+ if (connector != null) {
+ connector.activateTask(repositoryManager.getRepository(task. getRepositoryUrl()),
task);
for (ITaskActivationListener listener : new
ArrayList<ITaskActivationListener>(activationListeners)) {
try {
listener.taskActivated(task);
@@ -452,6 +458,12 @@
((AbstractTask) activeTask).setActive(false);
activeTask = null;
+ connector.deactivateTask(repositoryManager.getRepository(tas k.getRepositoryUrl()));
try {
listener.taskDeactivated(task);
Index: src/org/eclipse/mylyn/internal/tasks/core/AbstractTask.java
RCS file:
/cvsroot/tools/org.eclipse.mylyn/org.eclipse.mylyn.tasks.cor e/src/org/eclipse/mylyn/internal/tasks/core/AbstractTask.jav a,v
retrieving revision 1.34
diff -u -r1.34 AbstractTask.java
--- src/org/eclipse/mylyn/internal/tasks/core/AbstractTask.java 8 May 2009
04:43:30 -0000 1.34
+++ src/org/eclipse/mylyn/internal/tasks/core/AbstractTask.java 4 Jul 2009
22:49:43 -0000
@@ -84,6 +84,8 @@
private int estimatedTimeHours = 1;
+ private float totalTimeHours = -1;
private boolean markReadPending;
// TODO 4.0 make private
@@ -303,6 +305,14 @@
this.estimatedTimeHours = estimated;
+ public float getTotalTimeHours() {
+ return totalTimeHours;
+ public void setTotalTimeHours(float total) {
+ this.totalTimeHours = total;
void addParentContainer(AbstractTaskContainer container) {
containers.add(container);
Index: .refactorings/2009/7/27/refactorings.index
RCS file: .refactorings/2009/7/27/refactorings.index
diff -N .refactorings/2009/7/27/refactorings.index
--- /dev/null 1 Jan 1970 00:00:00 -0000
+++ .refactorings/2009/7/27/refactorings.index 1 Jan 1970 00:00:00 -0000
@@ -0,0 +1,1 @@
+1246743674234 Rename method 'acticateTask'
Index: .refactorings/2009/7/27/refactorings.history
RCS file: .refactorings/2009/7/27/refactorings.history
diff -N .refactorings/2009/7/27/refactorings.history
+++ .refactorings/2009/7/27/refactorings.history 1 Jan 1970 00:00:00 -0000
@@ -0,0 +1,4 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<session version="1.0">
+<refactoring comment="Rename method
&apos;org.eclipse.mylyn.tasks.core.AbstractRepositoryCon nector.acticateTask(...)&apos;
to &apos;activateTask&apos;&#x0D;&#x0A;- Original project:
&apos;org.eclipse.mylyn.tasks.core&apos;&#x0D;&a mp;#x0A;- Original element:
&apos;org.eclipse.mylyn.tasks.core.AbstractRepositoryCon nector.acticateTask(...)&apos;&#x0D;&#x0A;-
Renamed element:
&apos;org.eclipse.mylyn.tasks.core.AbstractRepositoryCon nector.activateTask(...)&apos;&#x0D;&#x0A;-
Update references to refactored element" delegate="false"
deprecate="false" description="Rename method &apos;acticateTask&apos;"
flags="589830" id="org.eclipse.jdt.ui.rename.method"
input=" /src&lt;org.eclipse.mylyn.tasks.core{AbstractRepositoryC onnector.java[AbstractRepositoryConnector~acticateTask~QITas k; "
name="activateTask" references="true" stamp="1246743674234" version="1.0"/>
+</session>
Re: Trac Timing and Estimation Plugin mylyn integration [message #70593 is a reply to message #70191] Tue, 14 July 2009 11:34 Go to previous messageGo to next message
Eclipse User
Originally posted by: seltmann.googlemail.com
Hello Phil,
Really nice, but before implementing this i would like to mention that
times are only counted for activated tasks when eclipse has the
window-focus. so every time you spend working on the activated issue
without using eclipse (i.e. answering mails, making calls, ...) is not
recognised as issue time.
ciao
Ulf
Re: Trac Timing and Estimation Plugin mylyn integration [message #70736 is a reply to message #70593] Wed, 15 July 2009 03:12 Go to previous messageGo to next message
Jörg Thönnes is currently offline Jörg Thönnes
See my answer some news below. Just deactivate the idle dection in the Tasks advanced preferences.
Jörg
Re: Trac Timing and Estimation Plugin mylyn integration [message #70745 is a reply to message #70191] Wed, 15 July 2009 03:13 Go to previous messageGo to next message
Hi Phil,
great stuff! Could you post a easy deployable plugin/feature for Eclipse 3.5 + Mylyn 3.2?
Anyway, please file a bug and attach your patch!
Thanks, Jörg
> don't have time to dig in right now and do it properly. What I did:
> so that Trac doesn't continue counting the time if somebody forgets to
> Index:
> RCS file:
> 22 Jun 2009 02:00:53 -0000 1.9
> 4 Jul 2009 22:49:40 -0000
> @@ -37,6 +37,7 @@
> @@ -232,4 +233,9 @@
> return null;
> Index:
> RCS file:
> 22 Jun 2009 02:00:53 -0000 1.20
> @@ -80,6 +80,7 @@
> import
> * @param replace
> same filename
> If <code>replace</code> is <code>true</code>, the
> generated filename of the attachment is returned.
> + @Override
> + try {
> + @Override
> + try {
> RCS file:
> 20 Jun 2009 07:32:02 -0000 1.10
> @@ -29,6 +29,7 @@
> Trac repositories.
> @@ -209,4 +210,7 @@
> TracException;
> RCS file:
> 2 Jul 2009 06:52:44 -0000 1.73
> + return;
> + return;
> + return;
> + return;
> RCS file:
> Jan 2009 07:05:20 -0000 1.25
> @@ -106,8 +106,8 @@
> } else {
> - e);
> Index:
> RCS file:
> 14 Jun 2009 23:38:26 -0000 1.106
> 4 Jul 2009 22:49:39 -0000
> @@ -31,6 +31,7 @@
> ITracClient.TICKET_URL + taskData.getTaskId());
> + @Override
> + @Override
> RCS file:
> - elapsedTotal +=
> child).getTotalTimeHours() * 3600 * 1000);
> + } else {
> + elapsedTotal +=
> estimateTotal));
> + sb.append("\n");
> + sb.append("\n");
> if (key != null) {
> + sb.append(" ");
> sb.append(key);
> + sb.append(" (");
> + sb.append(") ");
> + sb.append(", ");
> + sb.append(" [");
> + sb.append("]");
> + sb.append("\n");
> } else {
> return null;
> long elapsed =
> + sb.append("\n");
> RCS file:
> 1 May 2009 22:59:22 -0000 1.22
> 4 Jul 2009 22:49:41 -0000
> @@ -115,6 +115,7 @@
> RCS file:
> 17 Dec 2008 00:34:32 -0000 1.114
> 4 Jul 2009 22:49:43 -0000
> @@ -29,9 +29,7 @@
> - * - * Only methods that take a progress monitor can do network I/O.
> * * @author Mik Kersten
> * @author Rob Elves
> @@ -215,9 +213,8 @@
> - * + * Runs <code>query</code> on <code>repository</code>,
> results are passed to <code>collector</code>. If a
> {@link TaskData#isPartial()} will return true.
> * <p>
> * @@ -278,4 +275,9 @@
> RCS file:
> @@ -29,6 +29,7 @@
> @@ -103,7 +104,6 @@
> * * @see
> - * * @param startDay
> activeTask = task;
> task);
> try {
> activeTask = null;
> try {
> RCS file:
> 2009 04:43:30 -0000 1.34
> 2009 22:49:43 -0000
> @@ -84,6 +84,8 @@
> @@ -0,0 +1,1 @@
> -0000
> @@ -0,0 +1,4 @@
> Renamed element:
> +</session>
Re: Trac Timing and Estimation Plugin mylyn integration [message #70753 is a reply to message #70736] Wed, 15 July 2009 04:46 Go to previous messageGo to next message
Eclipse User
Ah, thanks!
even though i hope the task stops when i suspend my pc.
ciao
ulf
Re: Trac Timing and Estimation Plugin mylyn integration [message #70801 is a reply to message #70593] Wed, 15 July 2009 15:52 Go to previous messageGo to next message
Ulf Seltmann wrote:
> Hello Phil,
> ciao
> Ulf
Hi Ulf,
Thanks! Well this is not an issue, since the time is counted by the Trac
plugin.
Re: Trac Timing and Estimation Plugin mylyn integration [message #70814 is a reply to message #70745] Wed, 15 July 2009 16:00 Go to previous messageGo to next message
+ Mylyn 3.2?
Hi Jörg,
When I have more time I'll look into a 3.5 patch, but for now all I got is
3.3. I tried the ant build script but I guess I did something wrong, in
the end I had to work around the nested jars bug and export directly from
PDE.
Should I post the bug in the helpwanted or discussion bugs?
Re: Trac Timing and Estimation Plugin mylyn integration [message #70845 is a reply to message #70814] Thu, 16 July 2009 03:15 Go to previous messageGo to next message
On 07/15/09 22:00, phil wrote:
>> Eclipse 3.5
> + Mylyn 3.2?
Yes, of course!
> Hi Jörg,
> is 3.3. I tried the ant build script but I guess I did something wrong,
> in the end I had to work around the nested jars bug and export directly
> from PDE.
Hmmm, no idea. I would post it as a RFE and than attached your patches tagged as "Patch".
The keywords "helpwanted" is set by the committer if they need help from the community to develop a
feature.
Cheers, Jörg
Re: Trac Timing and Estimation Plugin mylyn integration [message #598112 is a reply to message #70191] Tue, 14 July 2009 11:34 Go to previous messageGo to next message
Ulf Seltmann is currently offline Ulf Seltmann
Hello Phil,
ciao
Ulf
Re: Trac Timing and Estimation Plugin mylyn integration [message #598165 is a reply to message #70593] Wed, 15 July 2009 03:12 Go to previous messageGo to next message
Jörg
Re: Trac Timing and Estimation Plugin mylyn integration [message #598168 is a reply to message #70191] Wed, 15 July 2009 03:13 Go to previous messageGo to next message
Hi Phil,
Thanks, Jörg
> Index:
> RCS file:
> @@ -37,6 +37,7 @@
> @@ -232,4 +233,9 @@
> return null;
> Index:
> RCS file:
> @@ -80,6 +80,7 @@
> import
> * @param replace
> same filename
> + @Override
> + try {
> + @Override
> + try {
> RCS file:
> @@ -29,6 +29,7 @@
> Trac repositories.
> @@ -209,4 +210,7 @@
> TracException;
> RCS file:
> + return;
> + return;
> + return;
> + return;
> RCS file:
> @@ -106,8 +106,8 @@
> } else {
> - e);
> Index:
> RCS file:
> @@ -31,6 +31,7 @@
> + @Override
> + @Override
> RCS file:
> - elapsedTotal +=
> + } else {
> + elapsedTotal +=
> estimateTotal));
> + sb.append("\n");
> + sb.append("\n");
> if (key != null) {
> + sb.append(" ");
> sb.append(key);
> + sb.append(" (");
> + sb.append(") ");
> + sb.append(", ");
> + sb.append(" [");
> + sb.append("]");
> + sb.append("\n");
> } else {
> return null;
> long elapsed =
> + sb.append("\n");
> RCS file:
> @@ -115,6 +115,7 @@
> RCS file:
> @@ -29,9 +29,7 @@
> * @author Rob Elves
> @@ -215,9 +213,8 @@
> * <p>
> RCS file:
> @@ -29,6 +29,7 @@
> @@ -103,7 +104,6 @@
> * * @see
> activeTask = task;
> task);
> try {
> activeTask = null;
> try {
> RCS file:
> 2009 22:49:43 -0000
> @@ -84,6 +84,8 @@
> @@ -0,0 +1,1 @@
> -0000
> @@ -0,0 +1,4 @@
> Renamed element:
> +</session>
Re: Trac Timing and Estimation Plugin mylyn integration [message #598179 is a reply to message #70736] Wed, 15 July 2009 04:46 Go to previous messageGo to next message
Ah, thanks!
ciao
ulf
Re: Trac Timing and Estimation Plugin mylyn integration [message #598209 is a reply to message #70593] Wed, 15 July 2009 15:52 Go to previous messageGo to next message
Ulf Seltmann wrote:
> Hello Phil,
> ciao
> Ulf
Hi Ulf,
plugin.
Re: Trac Timing and Estimation Plugin mylyn integration [message #598214 is a reply to message #70745] Wed, 15 July 2009 16:00 Go to previous messageGo to next message
+ Mylyn 3.2?
Hi Jörg,
PDE.
Re: Trac Timing and Estimation Plugin mylyn integration [message #598226 is a reply to message #70814] Thu, 16 July 2009 03:15 Go to previous messageGo to next message
>> Eclipse 3.5
> + Mylyn 3.2?
Yes, of course!
> Hi Jörg,
> from PDE.
feature.
Cheers, Jörg
icon5.gif  Re: Trac Timing and Estimation Plugin mylyn integration [message #642366 is a reply to message #70191] Tue, 30 November 2010 22:24 Go to previous messageGo to next message
Yevgeniy A. Viktorov is currently offline Yevgeniy A. Viktorov
I'm wondering how it's going, can't find anything except this thread Smile
Is it included into the current mylyn trac connector?
Thanks.
Re: Trac Timing and Estimation Plugin mylyn integration [message #644214 is a reply to message #642366] Thu, 09 December 2010 19:01 Go to previous message
Steffen Pingel is currently offline Steffen Pingel
The Trac connector does not currently have any support for the Timing and
Estimation Plugin. If you are interested in that feature please vote on this
bug:
168333: [activity] link repository fields to task fields
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168333
Steffen
Yevgeniy A. Viktorov wrote:
> Hello,
> I'm wondering how it's going, can't find anything except this thread :)
> Thanks.
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Previous Topic:Automated Context Managment
Next Topic:Is there a list of mediawiki markup tags supported for wikitext
Current Time: Thu May 23 16:22:19 EDT 2013
Powered by FUDForum. Page generated in 0.04913 seconds
