| Problems during loading my own Profile in standalone mode [message #643841] |
Wed, 08 December 2010 08:29  |
dieppi Messages: 27 Registered: November 2010 |
Junior Member |
i created UML Model with MagicDraw and exported as EMF UML2.x. So now ich have my model file *.uml and 5 profile files.
During code generation, in standalone mode using acceleo 3.x, my datatypes (from MagicDraw Profile) and my stereotypes (from my own profile) are empty. After debuging is saw the following
org.eclipse.uml2.uml.internal.impl.DataTypeImpl@2016b0 (eProxyURI: UML_Standard_Profile.MagicDraw_Profile.profile.uml#eee_10454 67100323_249638_60)
Ok i now i need to register the magic draw profile files and my own profile file. But how can i do this?
I have a method public void registerResourceFactories(ResourceSet resourceSet). Here i registered the UML Standard profile and metamodel via
URIConverter.URI_MAP.put(URI
.createURI(UMLResource.LIBRARIES_PATHMAP), uri
.appendSegment("libraries").appendSegment(""));
// UMLResource.METAMODELS_PATHMAP=pathmap://UML_LIBRARIES/
.createURI(UMLResource.METAMODELS_PATHMAP), uri
.appendSegment("metamodels").appendSegment(""));
// UMLResource.PROFILES_PATHMAP=UMLResource.PROFILES_PATHMAP
.createURI(UMLResource.PROFILES_PATHMAP), uri
.appendSegment("profiles").appendSegment(""));
But how can i register the other profiles or my own profiles? The profiles are in the same directory as the model file. In eclipse UML Model editor the profiles shown as
platform:/resources/UML_Standard_Profile.MagicDraw_Profile.p rofile.uml
Best regards
Maik
| Re: Problems during loading my own Profile in standalone mode [message #643853 is a reply to message #643841] |
Wed, 08 December 2010 08:39   |
Ed Merks Messages: 24570 Registered: July 2009 |
Maik,
Maik,
Did you load your model file using an absolute URI? If you're loading
from the file system, be sure to use java.io.File.getAbsolutePath before
converting it to a file URI.
Maik wrote:
> mailto:org.eclipse.uml2.uml.internal.impl.DataTypeImpl@2016b0
> (eProxyURI:
> 67100323_249638_60)
> via
> Best regards
> Maik
FUDForum. Page generated in 0.03608 seconds
