| Linke to folder in teh file system - problem [message #642420] |
Wed, 01 December 2010 04:31  |
dbrich Messages: 17 Registered: March 2010 Location: Austria |
Junior Member |
I have two projects using the same package structure, means the high qualifier is the same (in my case "rnd"). I need to use classes from one project in the other (but not via jar, as they are still "work in progress") - so I wanted to create a "link to folder in the file system" - unfortunately it fails.
In the project I create the link into are packages like "rnd.rap" and "rnd.views", the linked classes are in package "rnd.sockets".
It seems the link-process tries to create the directory "rnd", but it already exists, so the link-creation fails, instead of simply reusing the existing dir.
My work-around is to create the link in the OS (which is no problem in Linux, but would be one on Windows) - nevertheless I feel this is a bug and should work - but being an Eclipse beginner I want to check first, maybe I didn't understand some concept yet.
Any ideas, comments or suggestions?
Richard
| Re: Linke to folder in teh file system - problem [message #642524 is a reply to message #642420] |
Wed, 01 December 2010 11:26   |
Deepak Azad Messages: 545 Registered: July 2009 |
On 12/1/2010 3:01 PM, dbrich wrote:
> - unfortunately it fails. In the project I create the link into are
> the existing dir.
> Thanks
> Richard
Why don't you just add one project to the build path of the other ?
| Re: Linke to folder in teh file system - problem [message #642774 is a reply to message #642705] |
Thu, 02 December 2010 11:26   |
On 12/2/2010 6:30 PM, dbrich wrote:
> Please, bear with me as I am new to these technologies.
> Yes, I am developing a plug-in for a RAP (and RCP) target. But I also
> have some packages I need in this plug-in which I developed in plain
> Java (sockets and other utilities). I do not want to add them to the
> target, as that has to be done in a jar and is therefore not very
> flexible - the project is in start and I do make still changes to these
> classes on the go if I need it for the plug-in.
Right, the target contains already existing plug-ins.
> The source for these
> classes is actually in a SVN repository - my first idea was to create
> two additional projects and add them into the build path.That didn't
> work - I am actually getting syntax errors, as Eclipse does not find the
> classes even during coding.
What were the errors? This should have worked... maybe the classes were
not public? (Note that you could convert your plain java
projects/classes into a plug-in, just to use the plug-in dependency
mechanism.)
> Second idea was to add them as a external link - which also didn't work.
> Is there maybe other way to do it? I do not need the classes in a
> separate project in this workspace, but I didn't find any way to add a
> package from SVN (I do not want to add the classes, because there are
> too many to do it one by one).
| Re: Link to folder in the file system - problem [message #643729 is a reply to message #643594] |
Tue, 07 December 2010 21:56  |
On 12/7/2010 9:09 PM, dbrich wrote:
> Well, I am not able to recreate the syntax error - looks like you are
> right that adding the project into dependencies cures that problem.
> I still cannot run the plug-in though - it does not find the classes
> from these projects.
> I suppose I can make plug-in from my "plain" classes, but would that not
> mean to export them into a jar then?
A plugin is usually a jar :)
>If not that could be my solution -
> to create a "utilities" plug-in and put all these classes into it, could
> be even useful during deployment.
Exactly!
> But should not be possible to create a link to other file even if the
> high-level directory already exists?
Maybe, I did not look into this. The support for links was added to
Eclipse Platform recently and mostly for people doing C,C++ dev. In the
Java world I have not really seen a good use for links.
FUDForum. Page generated in 0.01719 seconds
