| how to adapt the generated objectsI have [message #643502] |
Tue, 07 December 2010 02:28  |
Tom H Messages: 136 Registered: July 2009 |
I have some EMF generated objects from an xsd and now have lots of classes like
Type1Request
Type2Request
Type3Request
Type4Request
Type5Request
I need to adapt those objects to a local interface called IMyRequest which specifies how to do something with the request objects
really I just want to check the type of the object and add a method to it, if it one of the classes above, something like;
public RequestAdapter(){
void RequestAdapter(EObject req){
switch(EObject)
case Type1Request :
case Type2Request::
case Type3Request::
case Type4Request:
//all is well
case SomeOtherObject:
throw NotSupportedException;
break;
public string process(){
do something here//
What pattern should I be looking at?
I am confused by EMF adapter patterns as they seem to be orientated towards adding notifications to objects rather than extra functionality.
Any suggestions would be welcome.Thanks
T
[Updated on: Tue, 07 December 2010 02:30] Report message to a moderator
| Re: how to adapt the generated objectsI have [message #643641 is a reply to message #643502] |
Tue, 07 December 2010 12:59  |
Ed Merks Messages: 24530 Registered: July 2009 |
Tom,
You could do it in the usual Java way with a bunch of instanceof tests
or use the generated switch. Look at the modelSwitch of the generated
XyzAdapterFactory as a good example.
> classes like
> Type1Request
> Type2Request
> Type3Request
> Type4Request
> Type5Request
> really I just want to check the type of the object and add a class to
> switch(EObject)
> case Type1Request :
> case Type2Request::
> case Type3Request::
> case Type4Request:
> //all is well
> break;
> do something here//
FUDForum. Page generated in 0.01982 seconds
