Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Project meta data is out of date for tools.buckminster
[buckminster-dev] Project meta data is out of date for tools.buckminster [message #643139] Sun, 05 December 2010 00:00
Eclipse Management Organization is currently offline Eclipse Management Organization
Henrik, Thomas,
Projects are required to keep meta data up to date using the MyFoundation
Portal (http://portal.eclipse.org/). The following problems were found
with this project's meta-data:
* The date for release "Helios SR1" is in the past, but the release is not
marked as completed. If it is completed, it should be marked as completed;
if it has been postponed, it should be given a new target date.
Previous Topic:Re: [buckminster-dev] Status on Buckminster Mercurial Plugin
Next Topic:SVN update during materialization
Current Time: Tue May 28 23:59:23 EDT 2013
Powered by FUDForum. Page generated in 0.05779 seconds
