Home » Eclipse Projects » GEF » Disable selection of figures in GEF
Disable selection of figures in GEF [message #642857] Thu, 02 December 2010 19:55 Go to next message
oinkl is currently offline oinkl
I'm using GEF to create a graphical editing application using Eclipse as an RCP.
In the graphical editor, I have a figure that draws a scale/ruler. How do I disable selection of this ruler figure?
Currently, whenever I click the ruler, the editor centres the view on the ruler. I don't want the ruler to even be clickable or selectable in the first place.
How do I achieve this?
Thanks.
[Updated on: Thu, 02 December 2010 21:09]
Report message to a moderator
Re: Disable selection of figures in GEF [message #644435 is a reply to message #642857] Sat, 11 December 2010 03:29 Go to previous messageGo to next message
Alexander Nyssen is currently offline Alexander Nyssen
EditPart#isSelectable() should do the trick. You will have to overwrite it for those edit parts that should not be selectable.
Cheers
Alexander
Re: Disable selection of figures in GEF [message #644526 is a reply to message #644435] Sun, 12 December 2010 21:41 Go to previous message
Excellent, that worked perfectly, thanks.
Previous Topic:draw2d interaction sequence
Next Topic:Can I change the cursor during DnD?
Current Time: Wed May 22 15:04:01 EDT 2013
Powered by FUDForum. Page generated in 0.01565 seconds
