Home » Modeling » M2T (model-to-text transformation) » execute an accelo plugin directly in the shell
execute an accelo plugin directly in the shell [message #642686] Thu, 02 December 2010 06:03 Go to next message
charfi asma is currently offline charfi asma
I built a compiler that needs to look at the MyClass file generated by an acceleo project.
I need to add the acceleo stuff in my compiler makefile,
In the shell, I will call my compiler that calls the Acceleo project to generate the file MyClass.
Is it possible ? if yes, can you explain what should I add to my compiler makefile,
I tried to run Acceleo in standlone (by running it as a java application) and compiling this java application in my makefile (calling javac, ...) but my model contains profile and I did not succed in loading it.
thanks
Asma
Re: execute an accelo plugin directly in the shell [message #643496 is a reply to message #642686] Tue, 07 December 2010 01:56 Go to previous message
Stephane Begaudeau is currently offline Stephane Begaudeau
I've never tried to load a model with profiles so I would advise you to ask your question in the EMF forum.
Stephane Begaudeau, Obeo.
Previous Topic:[Xpand] Root element not found
Next Topic:Acceleo 3.x - reset generate module problem
Current Time: Thu May 23 23:28:57 EDT 2013
Powered by FUDForum. Page generated in 0.01681 seconds
