Home » Eclipse Projects » BIRT » Running Birt in Linux for Domino designer (Running Birt in Linux for Domino designer )
Running Birt in Linux for Domino designer [message #640716] Mon, 22 November 2010 16:52 Go to next message
srikanth Missing name is currently offline srikanth Missing name
Member
Hello Everyone,
I am trying to deploy Birt on the Domino Designer in linux machine.
Below are the details of the set up
Dominno designer version : 8.5.2
Birt runtime version : 2.6.0
Birt engine path on linux machine : /opt/birt/ReportEngine/
I am trying to invoke the BIRT engine from a java class referred inside an Xpage with the following code..
EngineConfig config = new EngineConfig( );
config.setEngineHome("/opt/birt/ReportEngine" );
config.setLogConfig(null, Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );//engine = BIRTEngineFactory.getReportEngine(birtHomePath);//
engine.changeLogLevel( Level.WARNING );[/I]
It gives me the following exception
org.eclipse.birt.core.exception.BirtException: Can not startup the OSGI framework
11/22/2010 04:10:01 PM HTTP JVM: at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:91)
11/22/2010 04:10:01 PM HTTP JVM: at src.beans.BIRTEngineFactory.createEngineInstance(BIRTEngineF actory.java:33)
11/22/2010 04:10:01 PM HTTP JVM: at src.beans.BIRTEngineFactory.getReportEngine(BIRTEngineFactor y.java:19)
11/22/2010 04:10:01 PM HTTP JVM: at src.beans.ReportBuilder.run(ReportBuilder.java:148)
11/22/2010 04:10:01 PM HTTP JVM: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
11/22/2010 04:10:01 PM HTTP JVM: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:48)
11/22/2010 04:10:01 PM HTTP JVM: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:37)
11/22/2010 04:10:01 PM HTTP JVM: at java.lang.reflect.Method.invoke(Method.java:600)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.types.JavaAccessObject.call(JavaAccessObject .java:321)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.types.FBSObject.call(FBSObject.java:161)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.ASTTree.ASTCall.interpret(ASTCall.java:175)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.ASTTree.ASTProgram.interpret(ASTProgram.java :119)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.ASTTree.ASTProgram.interpretEx(ASTProgram.ja va:139)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.JSExpression._interpretExpression(JSExpressi on.java:435)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.JSExpression.access$1(JSExpression.java:424)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.JSExpression$2.run(JSExpression.java:414)
11/22/2010 04:10:01 PM HTTP JVM: at java.security.AccessController.doPrivileged(AccessController .java:284)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.JSExpression.interpretExpression(JSExpressio n.java:410)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.JSExpression.evaluateValue(JSExpression.java :251)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.jscript.JSExpression.evaluateValue(JSExpression.java :234)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.javascript.JavaScriptInterpreter.interpret(JavaS criptInterpreter.java:220)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.javascript.JavaScriptInterpreter.interpret(JavaS criptInterpreter.java:192)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.binding.javascript.JavaScriptValueBinding.getVal ue(JavaScriptValueBinding.java:78)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.component.xp.XspOutputLabel.getValue(XspOutputLa bel.java:532)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.util.FacesUtil.convertValue(FacesUtil.java:1073)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.renderkit.html_basic.LabelRendererEx.encodeBegin (LabelRendererEx.java:86)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.renderkit.ReadOnlyAdapterRenderer.encodeBegin(Re adOnlyAdapterRenderer.java:119)
11/22/2010 04:10:01 PM HTTP JVM: at javax.faces.component.UIComponentBase.encodeBegin(UIComponen tBase.java:956)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.util.FacesUtil.renderComponent(FacesUtil.java:79 3)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.util.FacesUtil.renderComponent(FacesUtil.java:80 4)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.component.UIViewRootEx._renderView(UIViewRootEx. java:1272)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.component.UIViewRootEx.renderView(UIViewRootEx.j ava:1210)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.application.ViewHandlerExImpl.doRender(ViewHandl erExImpl.java:635)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.application.ViewHandlerExImpl._renderView(ViewHa ndlerExImpl.java:320)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.application.ViewHandlerExImpl.renderView(ViewHan dlerExImpl.java:355)
11/22/2010 04:10:01 PM HTTP JVM: at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderRe sponsePhase.java:103)
11/22/2010 04:10:01 PM HTTP JVM: at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.ja va:210)
11/22/2010 04:10:01 PM HTTP JVM: at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.j ava:120)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.controller.FacesControllerImpl.render(FacesContr ollerImpl.java:264)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.webapp.FacesServlet.serviceView(FacesServlet.jav a:219)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.webapp.FacesServletEx.serviceView(FacesServletEx .java:193)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.webapp.FacesServlet.service(FacesServlet.java:15 4)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.webapp.FacesServletEx.service(FacesServletEx.jav a:137)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.xsp.webapp.DesignerFacesServlet.service(DesignerFace sServlet.java:86)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.designer.runtime.domino.adapter.ComponentModule.invo keServlet(ComponentModule.java:538)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.domino.xsp.module.nsf.NSFComponentModule.invokeServl et(NSFComponentModule.java:1140)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.designer.runtime.domino.adapter.ComponentModule$Adap terInvoker.invokeServlet(ComponentModule.java:803)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.designer.runtime.domino.adapter.ComponentModule$Serv letInvoker.doService(ComponentModule.java:758)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.designer.runtime.domino.adapter.ComponentModule.doSe rvice(ComponentModule.java:527)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.domino.xsp.module.nsf.NSFComponentModule.doService(N SFComponentModule.java:1124)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.domino.xsp.module.nsf.NSFService.doServiceInternal(N SFService.java:513)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.domino.xsp.module.nsf.NSFService.doService(NSFServic e.java:342)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.designer.runtime.domino.adapter.LCDEnvironment.doSer vice(LCDEnvironment.java:304)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.designer.runtime.domino.adapter.LCDEnvironment.servi ce(LCDEnvironment.java:261)
11/22/2010 04:10:01 PM HTTP JVM: at com.ibm.domino.xsp.bridge.http.engine.XspCmdManager.service( XspCmdManager.java:291)
11/22/2010 04:10:01 PM HTTP JVM: Caused by:
11/22/2010 04:10:01 PM HTTP JVM: org.eclipse.birt.core.exception.CoreException: Access denied (java.lang.RuntimePermission getClassLoader)
11/22/2010 04:10:01 PM HTTP JVM: at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:90)
11/22/2010 04:10:01 PM HTTP JVM: at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:79)
In java.policy We have added all the permission for the birt home.
Any suggestions will be really helpfull
Re: Running Birt in Linux for Domino designer [message #640743 is a reply to message #640716] Mon, 22 November 2010 18:43 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
What is the content of this directory?
do you have a plugins and configuration directory? You should have a
config.ini in the configuration directory and to begin with it should
have nothing else.
Jason
On 11/22/2010 4:52 PM, srikanth wrote:
> Hello Everyone,
> framework
> actory.java:33)
> ssorImpl.java:48)
> tBase.java:956)
> erExImpl.java:635)
> ollerImpl.java:264)
> sServlet.java:86)
> SFService.java:513)
> 11/22/2010 04:10:01 PM HTTP JVM: Caused by: 11/22/2010 04:10:01 PM HTTP
> GILauncher.java:90)
Jason Weathersby
BIRT Exchange
Re: Running Birt in Linux for Domino designer [message #640817 is a reply to message #640743] Tue, 23 November 2010 04:57 Go to previous messageGo to next message
Member
Hi Jason,
Yes the folder which you mentioned are there. Apart from them the /opt/birt/ReportEngine/ directory contains the following folders
1).DS_Store
2)genReport.bat
3)samples
4)genReport.sh
5)lib
Srikanth
Re: Running Birt in Linux for Domino designer [message #640972 is a reply to message #640817] Tue, 23 November 2010 12:32 Go to previous messageGo to next message
Can you open a bug for this with the stack trace?
BTW I assume the process has write permission to the configuration
directory?
Jason
On 11/23/2010 4:57 AM, srikanth wrote:
> Hi Jason,
> 1).DS_Store
> 2)genReport.bat
> 3)samples
> 4)genReport.sh
> 5)lib
> Srikanth
Jason Weathersby
BIRT Exchange
Re: Running Birt in Linux for Domino designer [message #641201 is a reply to message #640972] Wed, 24 November 2010 09:38 Go to previous messageGo to next message
Member
Hi Jason
There is Write permission to the configuration
directory.
I have made the following line entry in conf.ini file..
osgi.configuration.area=/opt/birt/ReportEngine/Configuration /osgi
regards,
Srikanth
[Updated on: Wed, 24 November 2010 09:38]
Report message to a moderator
Re: Running Birt in Linux for Domino designer [message #641206 is a reply to message #641201] Wed, 24 November 2010 09:45 Go to previous messageGo to next message
When you try to startup do you get any log in the configuration folder?
Jason
On 11/24/2010 9:38 AM, srikanth wrote:
> Hi Jason
> There is Write permission to theconfiguration
> directory.
> regards,
> Srikanth
Jason Weathersby
BIRT Exchange
Re: Running Birt in Linux for Domino designer [message #642398 is a reply to message #641206] Wed, 01 December 2010 03:11 Go to previous messageGo to next message
Member
Hi Jason
I don not get any logs..
Srikanth
Re: Running Birt in Linux for Domino designer [message #642570 is a reply to message #642398] Wed, 01 December 2010 14:23 Go to previous message
Why did you add this line:
If you added this there should be a
/opt/birt/ReportEngine/Configuration/osgi directory created (i assume
the space is a typo).
The error you are getting indicates either the plugins can not be found
or the configuration directory is not writable.
Jason
On 12/1/2010 3:11 AM, srikanth wrote:
> Hi Jason
> Srikanth
Jason Weathersby
BIRT Exchange
Previous Topic:Disabling viewer options for birt reports J2EE (Eclispe)
Next Topic:Spacing in multi series pie chart
Current Time: Tue May 21 19:06:27 EDT 2013
Powered by FUDForum. Page generated in 0.03040 seconds
