Home » Archived » Tycho » Need to link a plugin against Java 1.4
Need to link a plugin against Java 1.4 [message #641916] Mon, 29 November 2010 03:54 Go to next message
Bernd is currently offline Bernd
Member
sadly, I have the need to link one of our plugins against the rt.jar of
Java 1.4. Is there a way with Tycho to do this?
I tried to configure the maven-osgi-compiler-plugin like in the snippet
below... without success. I tried it via the plugin and via the parent pom.
<pluginManagement>
<plugins>
<plugin>
<groupId>org.codehaus.tycho</groupId>
<artifactId>maven-osgi-compiler-plugin</artifactId>
<version>0.10.0</version>
<configuration>
<source>1.4</source>
<target>1.4</target>
<fork>true</fork>
<executable>D:\bin\java\x86\j2sdk1.4.2_12\bin\javac.exe</executable >
</configuration>
</plugin>
</plugins>
</pluginManagement>
Kind regards,
Bernd Vogt
Re: Need to link a plugin against Java 1.4 [message #641935 is a reply to message #641916] Mon, 29 November 2010 04:22 Go to previous messageGo to next message
Jan Sievers is currently offline Jan Sievers
you picked the wrong groupId.
It should be org.sonatype.tycho (since tycho 0.6.0)
Apart from that your configuration should be OK.
Regards^,
Jan
"Bernd Vogt" <bernd.vogt@innovations.de> wrote in message
news:icvpgm$522$1@news.eclipse.org...
> Hello,
> pom.
> <pluginManagement>
> <plugins>
> <plugin>
> <configuration>
> <fork>true</fork>
> </configuration>
> </plugin>
> </plugins>
> </pluginManagement>
> Kind regards,
> Bernd Vogt
Re: Need to link a plugin against Java 1.4 [message #641967 is a reply to message #641935] Mon, 29 November 2010 07:17 Go to previous messageGo to next message
Member
Thanks for the hint! Unfortunately, this leads to the next problem:
[ERROR] Failed to execute goal
org.sonatype.tycho:maven-osgi-compiler-plugin:0.10.0:compile
(default-compile) on project de.visualrules.runtime: Fatal error
compiling: compileoutOfProcess not supported -> [Help 1]
A short code review has confirmed that Tycho 0.10.0 (JDT compiler mojo)
doesn't support forking.
As a workaround I have tried to configure the maven-osgi-compiler-plugin
in a way that it uses the javac compiler from the maven-compiler-plugin.
With the result that javac couldn't resolve any class from my dependencies.
Is there any way to tell the maven-osgi-compiler-plugin against which
rt.jar he has to compile?
In PDE build I have to map specific jars to an execution environment:
J2SE-1.4=/home/var/j2sdk1.4.2_19/jre/lib/rt.jar
J2SE-1.5=/home/var/jdk1.5.0_22/jre/lib/rt.jar
JavaSE-1.6=/home/var/jdk1.6.0_18/jre/lib/rt.jar
Kind regards,
Bernd
Re: Need to link a plugin against Java 1.4 [message #641999 is a reply to message #641916] Mon, 29 November 2010 08:45 Go to previous messageGo to next message
Member
I got it! Configuring the bootclasspath argument of the JDT compiler
does the trick:
<pluginManagement>
<plugins>
<plugin>
<groupId>org.sonatype.tycho</groupId>
<version>${tychoVersion}</version>
<configuration>
<compilerId>jdt</compilerId>
<compilerArguments>
<bootclasspath>D:\bin\java\x86\j2sdk1.4.2_12\jre\lib\rt.jar </bootclasspath>
</compilerArguments>
</configuration>
</plugin>
</plugins>
</pluginManagement>
Re: Need to link a plugin against Java 1.4 [message #642058 is a reply to message #641916] Mon, 29 November 2010 12:15 Go to previous message
Member
FYI: https://issues.sonatype.org/browse/TYCHO-547
Previous Topic:Where are the JDT Core compiler logs or how do I have them created?
Next Topic:Aggregator pom?
Current Time: Sat May 18 20:46:40 EDT 2013
Powered by FUDForum. Page generated in 0.04887 seconds
