| [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641760] |
Sat, 27 November 2010 12:10  |
Originally posted by: koester.matthias.gmx.de
After changing my grammar - which included using the options backtrack
and memoize - my content assist throws an IllegalStateException "Stack
of grammar elements seems to be corrupt.". Here is the full stacktrace:
java.lang.RuntimeException: java.lang.IllegalStateException: Stack of
org.eclipse.xtext.ui.editor.contentassist.antlr.AbstractCont entAssistParser.getFollowElements(AbstractContentAssistParse r.java:163)
org.eclipse.xtext.ui.editor.contentassist.antlr.AbstractCont entAssistParser.getFollowElements(AbstractContentAssistParse r.java:84)
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.computeFollowElements(ParserBased ContentAssistContextFactory.java:517)
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.computeFollowElements(ParserBased ContentAssistContextFactory.java:483)
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.computeFollowElements(ParserBased ContentAssistContextFactory.java:478)
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.createContexts(ParserBasedContent AssistContextFactory.java:191)
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.create(ParserBasedContentAssistCo ntextFactory.java:130)
org.eclipse.xtext.ui.editor.contentassist.CompletionProposal Computer.exec(CompletionProposalComputer.java:48)
org.eclipse.xtext.ui.editor.contentassist.CompletionProposal Computer.exec(CompletionProposalComputer.java:1)
org.eclipse.xtext.util.concurrent.IStateAccess$AbstractImpl. readOnly(IStateAccess.java:40)
org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(Xte xtDocument.java:70)
org.eclipse.xtext.ui.editor.contentassist.XtextContentAssist Processor.computeCompletionProposals(XtextContentAssistProce ssor.java:79)
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(ContentAssistant.java:1834)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(CompletionProposalPopup.java:556)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$16(CompletionProposalPopup.java:553)
org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run(CompletionProposalPopup.java:488)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(CompletionProposalPopup.java:482)
org.eclipse.jface.text.contentassist.ContentAssistant.showPo ssibleCompletions(ContentAssistant.java:1660)
org.eclipse.jface.text.source.SourceViewer.doOperation(Sourc eViewer.java:913)
org.eclipse.jface.text.source.projection.ProjectionViewer.do Operation(ProjectionViewer.java:1534)
org.eclipse.ui.texteditor.ContentAssistAction$1.run(ContentA ssistAction.java:82)
org.eclipse.ui.texteditor.ContentAssistAction.run(ContentAss istAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:185)
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:468)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:786)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:885)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:567)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:508)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:123)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:152 5)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1257)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1294 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:730)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2839)
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:734)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1743)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4794 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4372 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:81 63)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1239)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:2224)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3169)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Looking at the source code didn't give me a hint what might have gone
wrong. And searching bugzilla and google didn't help either. The only
unusual thing I do in my project is to use a post process to move some
features from subclasses to their common super class. Can this cause
this problem? Or is it caused by my grammar?
Matthias
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641806 is a reply to message #641778] |
Sun, 28 November 2010 05:00   |
Hi Meinte,
I've read the documentation about the model interference and currently I
don't see another way than a post processor to shape my metamodel as I
want it to look like;-) But since my experience with Xtext is still
growing, perhaps I can get rid of the post processor in the future;-)
But my guess is that as long as Xtext works with a subclass it shouldn't
matter if a feature is defined in the superclass or the subclass!
Otherwise I would have been very surprised and it would break the
principle of least astonishement...
As Sebastian stated it seems to be either a problem with my grammar or
perhaps a bug. We will investigate it further and report back.
Matthias
Meinte Boersma schrieb:
> Eclipse User wrote on Sat, 27 November 2010 18:10
>> The only unusual thing I do in my project is to use a post process to
>> move some features from subclasses to their common super class. Can
>> this cause this problem? Or is it caused by my grammar?
> This is suspicious: Xtext performs a normalization of the Ecore before
> the postprocessing, so normally there can't be any need to do this
> yourself. It could very well be that you modify the Ecore model in a way
> which is incompatible with what Xtext expects (see "Ecore Model
> Inference" in the Xtext User Guide).
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641809 is a reply to message #641803] |
Sun, 28 November 2010 06:03   |
Hi Sebastian,
Removing memoize=true didn't help, but it looks like my scope providers
are causing the problem: I copied my grammar to a new xtext project
without my scope providers and there the content assist worked. Of
course without the interesting stuff ;-)
I will investigate this problem further, but just wanted to hear if you
think that the problem can also be caused by my scope providers?
Matthias
Sebastian Zarnekow schrieb:
> Hi Matthias,
> the exception signals a violation of an invariant in the content assist
> parser. It is unlikely that your Ecore model post-processing has
> something to do with it. Could you please file a ticket with a
> reproducable sample attached? Does it help if you turn memoization off?
> Sebastian
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641811 is a reply to message #641809] |
Sun, 28 November 2010 06:09   |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
Hi Matthias,
at a first glance I'd doubt that a scope provider implementation can
cause this exception.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 28.11.10 12:03, schrieb Matthias Köster:
> Hi Sebastian,
> Best regards,
> Matthias
>> Hi Matthias,
>> assist parser. It is unlikely that your Ecore model post-processing
>> has something to do with it. Could you please file a ticket with a
>> Regards,
>> Sebastian
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641815 is a reply to message #641811] |
Sun, 28 November 2010 06:36   |
I encountered another strange thing: When I disable the backtrack and
memoize option for my parser.antlr.XtextAntlrUiGeneratorFragment the
generation fails. That's fine, but when I now regenerate everything with
option backtrack=true I get the following ANTLR error:
error(10): internal error:
org.antlr.tool.Grammar.createLookaheadDFA(Grammar.java:864): could not
even do k=1 for decision 10
Now the strange thing:
When I generate everything a second time, the ANTLR error doesn't show
up! As far as I can see my MWE should clean the generated source before
each run, but now it seems to store some state between runs... Or why
does my generator fail during the first run and fails on the second run?
Matthias
> Hi Matthias,
> Sebastian
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641823 is a reply to message #641815] |
Sun, 28 November 2010 09:31   |
Hi Matthias,
Antlr uses an internal timeout when it's analyzing the grammar. Your
observation should not have something to do with first and second time
generation.
See here:
http://20000frames.blogspot.com/2010/09/dealing-with-could-n ot-even-do-k1-for.html
Sebastian
Am 28.11.10 12:36, schrieb Matthias Köster:
> Matthias
>> Hi Matthias,
>> Regards,
>> Sebastian
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641901 is a reply to message #641823] |
Mon, 29 November 2010 03:05   |
Hi Sebastian,
I fixed my problem by patching the
class. Stripping down my xtext project to a reasonable size requires
more time than I can invest right now, but my example is open sourced at
google code. The patch is actually very easy, to me it looks like an if
statement in method getFollowElements(final
AbstractInternalContentAssistParser parser, AbstractElement
elementToParse, String[] ruleNames, int startIndex)
isn't correct.
So how can we proceed to solve the problem? Should I file a bug request
with a pointer to my open source project or is it enough when I add the
patch to my bug request?
Matthias
> Hi Matthias,
> generation.
> See here:
> Sebastian
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641915 is a reply to message #641895] |
Mon, 29 November 2010 03:37   |
Hi Alex,
Thx for your hint, but I already knew that I can start from a metamodel
and then create a Xtext grammar to map to it ;-)
Since my post processor doesn't seem to cause the problem, I'm fine with
my current approach ;-)
I like the DRY principle and it's great that Xtext is supporting it. For
me one of the main benefits of using Xtext is the fast turn around time.
Before using Xtext I used ANTLR and DLTK. That gave me the full power of
ANTLR (like predicates, etc.), but I had to synchronize my grammar with
my metamodel manually. That was really time consuming and wasn't fun at
all.
Another stumbling block was using DLTK. It's really a great framework,
but it's still lacking documentation. And the source code isn't very
easy to understand, especially when compared with Xtext! And the Xtext
community is much bigger and much nicer;-)
Matthias
Alexander Nittka schrieb:
>> I don't see another
>> way than a post processor to shape my metamodel as I want it to look
>> like;-)
> have you tried instantiating an existing meta model? You need not use
> the one generated automatically.
> Alex
| Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641923 is a reply to message #641901] |
Mon, 29 November 2010 04:31   |
Hi Matthias,
a patch and a test case would be great.
Sebastian
Am 29.11.10 09:05, schrieb Matthias Köster:
> Hi Sebastian,
> isn't correct.
> Best regards,
> Matthias
>> Hi Matthias,
>> generation.
>> See here:
>> Regards,
>> Sebastian
FUDForum. Page generated in 0.02201 seconds
