Home » Modeling » Modeling (top-level project) » EMF : get Eclass from ClassifierID
EMF : get Eclass from ClassifierID [message #641649] Fri, 26 November 2010 08:37 Go to next message
Sébastien  Gandon is currently offline Sébastien Gandon
I use the ClassifierID to identify some class type that I use in server-client application.
I need to recreate the model from the classifier ID that is create instances, using my factory but using ClassifierId.
Or the creation method all use EClass definition and not Classifier.
Is there any Utilities method or genereted method to create an Instance from the ClassifierID or to get the EClass instance from the classifier.
I have noticied that the Factory implementation already has a switch with the ClassifierID but embeded in a Create(EClass) method.
Re: EMF : get Eclass from ClassifierID [message #641658 is a reply to message #641649] Fri, 26 November 2010 09:46 Go to previous message
Ed Merks is currently offline Ed Merks
Sébastien,
Please use the EMF newsgroup (eclipse.tools.emf) for questions about
EMF. More comments below.
Sébastien Gandon wrote:
> Hello,
It's typically better to use the name, at least for any long term storage...
You'll need to know the package/factory as well then.
Yes, because an EClassifier can be either an EClass (instances of which
are EObjects) or an EDataType (instances of which can be any Java type).
> classifier.
No, because creating an instance of an EDataType requires some
information from which to create it. E.g., you can't create a Integer
unless you specify the value it should have.
Yes, it only covers the classifiers that represent classes.
Previous Topic:ANSI-C-model and dealing with redundant references
Next Topic:generics in ecore model
Current Time: Sun May 26 02:57:56 EDT 2013
Powered by FUDForum. Page generated in 0.01822 seconds
