Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Generate Sequence Diagram for Code running in remote Application server(Generate Sequence Diagram for Code running in remote Application server)
Generate Sequence Diagram for Code running in remote Application server [message #640553] Mon, 22 November 2010 08:31 Go to next message
SC  is currently offline SC
I am able to generate sequence diagram for a simple HelloWorld example which has a java main using TPTP. Now I want to generate sequence diagram for a code running in a remote application server. I am able to connect to remote server after doing relevant setting, but I am not getting an option to view class interactions in UML view. Please can you advise if its doable or not using TPTP? If yes, any pointers on how that can be done.
Re: Generate Sequence Diagram for Code running in remote Application server [message #641514 is a reply to message #640553] Thu, 25 November 2010 13:53 Go to previous message
Jonathan West is currently offline Jonathan West
Member
Hi SC,
In order for this option to appear, you must ensure that you have specified the following to the CGProf profiler JVM arguments
execdetails=true
For example, to profile Class with execdetails:
java -agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf:execd etails=true Class
More information on this is available in the gettingstarted.html file of the standalone agent controller.
[Updated on: Thu, 25 November 2010 13:54]
Report message to a moderator
Previous Topic:why the packages not list in the Execution Statistics page
Next Topic:A time-out error when attempting to profile large application
Current Time: Sat May 25 19:32:29 EDT 2013
Powered by FUDForum. Page generated in 0.05224 seconds
