Home » Eclipse Projects » DSDP - Target Management » IRemoteFile.exists() returns true but can't download file with following message(RSEG9999, Missing element for : '')
icon5.gif  IRemoteFile.exists() returns true but can't download file with following message [message #641328] Wed, 24 November 2010 21:50 Go to next message
Mark Anderson is currently offline Mark Anderson
There are some files which reperesented by multi-byte(korean) language in remote server.
Before I download it programatically , I made IRemoteFile instance 'root' by following code;
IRemoteFileSubSystem s = RemoteFileUtility.getFileSubSystem(host);
s.setConnectorService(conService); // connector service from pre-created host
IRemoteFile root = s.getRemoteFileObject("/home/myusr/테스트.txt", monitor); // file name contains korean language
IRemoteFileSubSystem srcFS = root.getParentRemoteFileSubSystem();
if (!srcFS.isConnected() || !root.exists())
    return false;
if (root.isFile())
    srcFS.dowload(.......);
In case of Korean file name, IRemoteFile's instance root was succesfully created and root.exists() returns true.
However, srcFS.download() method throws Exception with following message.
org.eclipse.rse.services.clientserver.messages.SystemElementNotFoundException: Missing element for : ''
	at org.eclipse.rse.internal.services.ssh.files.SftpFileService.makeSystemMessageException(SftpFileService.java:447)
	at org.eclipse.rse.internal.services.ssh.files.SftpFileService.download(SftpFileService.java:876)
	at org.eclipse.rse.subsystems.files.core.servicesubsystem.FileServiceSubSystem.download(FileServiceSubSystem.java:807)
So I double checked how RSE work in the Remote Systems view from Remote Systems Explorer perspective.
I've got an error dialog "RSEG9999, Missing element for : ''"
I think that is is same with my situation.
In order to work correctly what can I do next.
I would appreciate any comments.
Have a nice day~
[Updated on: Wed, 24 November 2010 21:55]
Report message to a moderator
Re: IRemoteFile.exists() returns true but can't download file with following message [message #641369 is a reply to message #641328] Thu, 25 November 2010 03:49 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
Hi Mark,
This seems to be an encoding problem. Apparently you use SSH on the
wire. Thus your issue could be related to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236334
You could also try explicitly setting the encoding in your connection's
properties (Select connection, right-click properties, Host properties,
encoding; you can also do this programmatically). This feature request
is open for SSH to auto-detect the remote encoding:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244404
As a workaround, you could also try using dstore which uses a
Java/XML/Unicode transfer mechanism and can thus better deal with
encodings. This requires that you can run a dstore server on the remote.
Even FTP file transfer might be able to better deal with encodings in
this particular case.
HTH
Martin
Previous Topic:How to create SubSystem Programatically?
Next Topic:Connection errors using RSE
Current Time: Mon May 20 07:53:57 EDT 2013
Powered by FUDForum. Page generated in 0.01915 seconds
