Home » Eclipse Projects » BIRT » Y-axis format(Can't format y-axis properly)
Y-axis format [message #559628] Fri, 17 September 2010 09:02 Go to next message
Tomas Greif is currently offline Tomas Greif
Member
I can't format y-axis properly (bar chart with with one series of data only).
Whatever I do the result is always in scientific format (e.g. 300E1 for 3.000). It is interesting that it works correctly for different chart in the same report.
Dataset is based on query (postgres), datatype of the column is NUMERIC.
I am using BIRT Report Designer 2.6, Birt Report Viewer (together with jboss)
Any idea what can cause such behavior?
Tomas
Re: Y-axis format [message #559703 is a reply to message #559628] Fri, 17 September 2010 11:42 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
What is your y-axis type set to?
Linear or logarithmic (third tab on wizard-click on Axis)? Can you post
the report?
Jason
On 9/17/2010 9:02 AM, TomasGreif wrote:
> only).
> the same report.
> jboss)
> Tomas
Jason Weathersby
BIRT Exchange
Re: Y-axis format [message #559720 is a reply to message #559703] Fri, 17 September 2010 12:53 Go to previous messageGo to next message
Member
It is set to linear.
Snapshot of the report can be found here: http://www.collectionspro.eu/axis.JPG
The report itself (I have deleted some other charts and I also renamed the remaining charts) is here: http://www.collectionspro.eu/report_yaxis.rptdesign
Maybe I should also add there I am using shared data library (.rptlibrary)
I was thinking that some custom format might help, however I haven't found any custom format description so far.
Please let me know if you need more information, I really like BIRT, however such reports cannot be used in live environment.
EDIT: fyi... I get the same results using tomcat
Tomas
[Updated on: Mon, 20 September 2010 08:26]
Report message to a moderator
Re: Y-axis format [message #641189 is a reply to message #559720] Wed, 24 November 2010 09:08 Go to previous message
Jerome Godard is currently offline Jerome Godard
Hello, I get exactly the same issue, did you find a way to fix it? or do you have any workaround?
Jérôme
Previous Topic:Change locale via report-parameter
Next Topic:PDF rendering issue
Current Time: Mon May 20 12:33:37 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
