Home » Eclipse Projects » Virgo » Running Virgo in Eclipse
Running Virgo in Eclipse [message #641017] Tue, 23 November 2010 17:03 Go to next message
Dennis is currently offline Dennis
I previously was able to get Spring-DM Server to run in eclipse, but seem to no longer be able to do that with the Virgo upgrade.
Eclipse gives me the following error when I attempt to set Virgo up as a Server:
.version file in lib directory is missing key 'dm.server.version'. Make sure to point to a dm Server 2.0 installation.
I am still using the Spring-DM Tools, is there a different plugin that i should be using?
Thanks.
Re: Running Virgo in Eclipse [message #641043 is a reply to message #641017] Tue, 23 November 2010 23:29 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
You need to obtain the latest level of the tools as described in the Virgo Programmer Guide. Then create a Virgo server under the EclipseRT section rather than a SpringSource dm Server under the Spring (?) section - see section 7.2 of the Programmer Guide.
Re: Running Virgo in Eclipse [message #641179 is a reply to message #641043] Wed, 24 November 2010 08:37 Go to previous message
Good call. Thanks.
Previous Topic:Classloader Exception during EntityManager setup
Next Topic:Class loader exception during JPA processing
Current Time: Tue May 21 05:11:41 EDT 2013
Powered by FUDForum. Page generated in 0.03770 seconds
