Home » Modeling » B3 » Cannot install b3 Aggregator into 3.7 M3.
Cannot install b3 Aggregator into 3.7 M3. [message #640453] Mon, 22 November 2010 02:40 Go to next message
Gunnar Wagenknecht is currently offline Gunnar Wagenknecht
I'm having a bit of trouble installing b3 Aggregator into my 3.7 SDK.
I'm following the directions posted here:
http://wiki.eclipse.org/Eclipse_b3/aggregator/manual#Eclipse _SDK_installation
Using this update site:
http://download.eclipse.org/modeling/emft/b3/updates-3.7mile stones
That's what I get:
Cannot complete the install because of a conflicting dependency.
Software being installed: b3 Aggregator Editor (Incubation)
0.1.0.r01404 (org.eclipse.b3.aggregator.editor.feature.feature.group
0.1.0.r01404)
Software currently installed: Eclipse SDK 3.7.0.I20101028-1441
(org.eclipse.sdk.ide 3.7.0.I20101028-1441)
Only one of the following can be installed at once:
ECF Core API 3.1.0.v20100529-0735 (org.eclipse.ecf 3.1.0.v20100529-0735)
ECF Core API 3.1.0.v20100906-1425 (org.eclipse.ecf 3.1.0.v20100906-1425)
Cannot satisfy dependency:
From: b3 Aggregator Editor (Incubation) 0.1.0.r01404
(org.eclipse.b3.aggregator.editor.feature.feature.group 0.1.0.r01404)
To: org.eclipse.b3.aggregator.engine.feature.feature.group
[0.1.0.r01404]
From: b3 Aggregator Engine (Incubation) 0.1.0.r01404
(org.eclipse.b3.aggregator.engine.feature.feature.group 0.1.0.r01404)
To: org.eclipse.ecf [3.1.0.v20100529-0735]
2.0.0.v20100503-897OFx-FdHjO2NkE10Uc8KQ
(org.eclipse.equinox.p2.user.ui.feature.group
2.0.0.v20100503-897OFx-FdHjO2NkE10Uc8KQ)
To: org.eclipse.ecf [3.1.0.v20100906-1425]
From: Eclipse SDK 3.7.0.I20101028-1441 (org.eclipse.sdk.ide
To: org.eclipse.equinox.p2.user.ui.feature.group
[2.0.0.v20100503-897OFx-FdHjO2NkE10Uc8KQ]
Any ideas?
Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Cannot install b3 Aggregator into 3.7 M3. [message #640539 is a reply to message #640453] Mon, 22 November 2010 07:33 Go to previous messageGo to next message
Filip Hrbek is currently offline Filip Hrbek
We are preparing a new build for 3.7milestones. When we are done, we'll try to install it into a fresh 3.7. I'll keep you informed about the result here later today.
Filip
Dne 22.11.2010 08:40, Gunnar Wagenknecht napsal(a):
> That's what I get:
> 0.1.0.r01404)
> [0.1.0.r01404]
> From: Equinox p2 Provisioning
> Any ideas?
> Gunnar
Re: Cannot install b3 Aggregator into 3.7 M3. [message #641072 is a reply to message #640539] Wed, 24 November 2010 03:16 Go to previous messageGo to next message
Am 22.11.2010 13:33, schrieb Filip Hrbek:
Still no luck today. I wonder if the version ranges are too strict.
-Gunnar
Gunnar Wagenknecht
Re: Cannot install b3 Aggregator into 3.7 M3. [message #641082 is a reply to message #641072] Wed, 24 November 2010 03:31 Go to previous message
Unfortunately there are API changes that need to be reflected in the aggregator code. We created a new build for 3.6 (which has been published) but the build for 3.7 will require more effort (no problem in the actual build but in adopting to the new API).
Stay tuned.
Filip
Dne 24.11.2010 09:16, Gunnar Wagenknecht napsal(a):
> -Gunnar
Previous Topic:Status of b3 building tool
Next Topic:UnsupportedOperationException with 3 repositories
Current Time: Sun May 19 11:03:27 EDT 2013
Powered by FUDForum. Page generated in 0.09243 seconds
