Home » Eclipse Projects » Virgo » Best practice question?
Best practice question? [message #640345] Sat, 20 November 2010 19:09 Go to next message
Bojan Kraut is currently offline Bojan Kraut
My question is regarding architecture of greenpages application.
There is a jpa bundle, which uses db bundle to get necessary data to connect to the database. jpa bundle instantiates an enttymanager which is used to access the data.
Let say id like to have two additional bundles - orders and invoices, which would use the same entitymanager. Is this possible? Or every bundle must have its own entity manager defined? How are runtime data shared? Is let say an account[id=5435] loaded in memory in two bundles or can both bundles access the same information?
Bojan
Re: Best practice question? [message #640548 is a reply to message #640345] Mon, 22 November 2010 08:23 Go to previous message
guofeng zhang is currently offline guofeng zhang
Member
If your each bundle needs a EntityManagerFactory, you might need to publish the EntityManagerFactory as a service, then get or inject the service to your bundle.
see http:// www.eclipse.org/forums/index.php?t=msg&th=198496&sta rt=0&S=3da08bead6b17caaec5cf954fe49be85
Previous Topic:Hudson CI
Next Topic:Greenpages sample problem
Current Time: Sun May 19 04:36:34 EDT 2013
Powered by FUDForum. Page generated in 0.04941 seconds
