Home » Language IDEs » Java Development Tools (JDT) » Shortcut Key to Select Token
Shortcut Key to Select Token [message #635490] Wed, 27 October 2010 05:09 Go to next message
No real name is currently offline No real nameFriend
What is the shortcut key to select a token or word?
Re: Shortcut Key to Select Token [message #635497 is a reply to message #635490] Wed, 27 October 2010 06:52 Go to previous messageGo to next message
Satyam Kandula is currently offline Satyam KandulaFriend
Control+Shift+Right is probably the one that you are looking for. However Window->Preferences->Keys could give you the short cuts and you could bind your keys for those that doesn't have.
Re: Shortcut Key to Select Token [message #635655 is a reply to message #635490] Wed, 27 October 2010 15:59 Go to previous messageGo to next message
That only selects part of the token if it's camel case. For example if the cursor is between the "r" and "i" in the token "myVariableName", only the characters "iable" will be selected.
Re: Shortcut Key to Select Token [message #635676 is a reply to message #635490] Wed, 27 October 2010 16:59 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
To progressively select java statements, you can use ALT+SHIFT+UP_ARROW.
To search for the text occurrence of the current highlighted word, you
can use CTRL+K
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Shortcut Key to Select Token [message #636268 is a reply to message #635490] Sat, 30 October 2010 04:58 Go to previous messageGo to next message
We really need a select word shortcut.
Re: Shortcut Key to Select Token [message #636423 is a reply to message #636268] Mon, 01 November 2010 08:18 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=23080 Not what you
asked for but just in case: you could use double-click.
Dani
Re: Shortcut Key to Select Token [message #640101 is a reply to message #635490] Fri, 19 November 2010 06:02 Go to previous message
Double-click selects too much. For example, if the word is a string literal, the quotes around the word will be selected.
Please vote to have this essential keyboard shortcut implemented.
Previous Topic:Classpath Build Order Changes
Next Topic:Eclipse SDK for "hpux.motif.ia64" 64 bit
Current Time: Sat Jul 22 09:04:40 GMT 2017
Powered by FUDForum. Page generated in 0.04475 seconds
