Home » Modeling » M2T (model-to-text transformation) » Class with any operation with more of one parameter(Class with any operation with more of one parameter)
Class with any operation with more of one parameter [message #639642] Wed, 17 November 2010 05:23 Go to next message
olafo987  is currently offline olafo987
How I can determine if one Class have some operation with more of one parameter?.
if in my model UML I have the following classes:
ContractService
public delecteContract(pContract : Contract, pCustomer costumer) : Contract
______
TypeContractservice
addTypeContr(pTypeContract : TypeContract) : TypeContract
deleteTypeCont(pTypeContract : TypeContract) : TypeContract
_____
I should find only ContractService
Re: Class with any operation with more of one parameter [message #639669 is a reply to message #639642] Wed, 17 November 2010 07:15 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
--------------070602010404020307080104
Content-Type: text/plain; charset=UTF-8; format=flowed
Please prefix your post subjects with the name of the tool you're using.
Is that XPand, Acceleo, Jet? Your message doesn't mention any hint
towards this.
If you're using Acceleo, you could use the following (starting from a
package):
[package.packagedElements->filter(Class)->select(ownedOperations- >select(parameters->size()
> 1)->notEmpty())/]
There are less convoluted means depending on where exactly you wish to
filter these classes, but that's the whole thing.
Laurent Goubet
Obeo
On 17/11/2010 11:23, olafo987 wrote:
> Hi
> parameter?.
> ContractService
> ______
> TypeContractservice
> _____
> Thanks
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------070602010404020307080104--
Re: Class with any operation with more of one parameter [message #640337 is a reply to message #639642] Sat, 20 November 2010 15:00 Go to previous message
In OCL as in many other things you proceed in stages
First select all relevant classes; allInstances if you don't have
anything better,
the select all operations
then count parameters
then compare the count with 1
Ed Willink
On 17/11/2010 10:23, olafo987 wrote:
> Hi
> parameter?.
> ContractService
> Contract
> ______
> TypeContractservice
> _____
> Thanks
Previous Topic:[Acceleo 3 - ocl] a "loop" question
Next Topic:[Acceleo 3] Iteration over the types of a model
Current Time: Thu May 23 21:10:20 EDT 2013
Powered by FUDForum. Page generated in 0.08972 seconds
