Home » Eclipse Projects » EclipseLink » [EclipseLink 2.1.1 / SDO] DataGraph Support([EclipseLink 2.1.1 / SDO] DataGraph Support)
[EclipseLink 2.1.1 / SDO] DataGraph Support [message #639080] Mon, 15 November 2010 04:03 Go to next message
Martin Weiss is currently offline Martin Weiss
I am wondering whether we have (still ?) SDO DataGraph support in EclipseLink 2.1.1. The DataGraph interface is deprecated. Should I therefore use SDODataGraph no more...
I try to apply the following XSD defintion (sample in SDO 2.1.1 specs), but the SDO compiler fails (BaseDataGraphType not recognized):
<element name="companyDatagraph" type="company:CompanyDataGraphType"/>
<complexType name="CompanyDataGraphType">
<complexContent>
<extension base="sdo:BaseDataGraphType">
<sequence>
<element name="company" type="company:CompanyType"/>
</sequence>
</extension>
</complexContent>
</complexType>
Many thanks for your help.
Martin
Re: [EclipseLink 2.1.1 / SDO] DataGraph Support [message #639557 is a reply to message #639080] Tue, 16 November 2010 16:37 Go to previous message
Blaise Doughan is currently offline Blaise Doughan
Hi Martin,
You are correct DataGraph has been deprecated and should not be used. It is recommended practice to use a DataObject instead.
-Blaise
Previous Topic:[SOLVED]Problem with @Converter and smallint field
Next Topic:unexpected behavior using refreshAndLockObject
Current Time: Sat May 18 08:05:03 EDT 2013
Powered by FUDForum. Page generated in 0.02023 seconds
