Home » Eclipse Projects » DSDP - Target Management » can't debug remotely
can't debug remotely [message #583135] Mon, 08 March 2010 09:03 Go to next message
Nicolas  is currently offline Nicolas
I read in the FAQ it was possible to remotely debug an application, but couldn't set ip up.I'm trying to debug a Unix app on Windows.
On the Unix box I have a SSH server, a samba server, gdb, gdbserver, and my application compiled with gcc -g.
On the Windows box I have Eclipse-CDT and RSE. Why does the debug window ask for the application ? Should I point to the samba-shared Unix application, or copy it on the Windows box hard-drive (about network bandwidth) ? also, do I need to add the (samba-shared) source files to the Eclipse project ?
What else do I need ? First I'll try to debug a simple "Hello World" Linux app from Windows.
Thanks a lot,
Nicolas
Re: can't debug remotely [message #639522 is a reply to message #583135] Tue, 16 November 2010 14:10 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
you need a cross debugger on Windows. This should have been clear from
the FAQ's. If it's not clear enough, please edit the FAQ Wiki to make it
more clear.
Martin
Previous Topic:Dialog to specify file
Next Topic:using RSE in OSGi containers (Equinox)
Current Time: Wed May 29 03:50:27 EDT 2013
Powered by FUDForum. Page generated in 0.01992 seconds
