Home » Eclipse Projects » DSDP - Target Management » Dialog to specify file
Dialog to specify file [message #583156] Thu, 18 March 2010 13:14 Go to next message
Vladimir Prus is currently offline Vladimir Prus
I am looking for an RSE dialog suitable for specifying a file to *create* on remote system.
Originally, I have used SystemRemoteFileDialog but it appears to be not suitable for specifying files that do not exist.
I've also tried to use SaveAsDialog, but got NPE (because it does not initialize the filename, and then tries to call trim on a null string), and it's base class is marked as deprecated.
Before I continue poking around, could somebody tell me what is the official way/approach to achieve what I want?
Re: Dialog to specify file [message #639521 is a reply to message #583156] Tue, 16 November 2010 14:09 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
have you considered using PDE Plug-in Spy?
Doing "New File" in RSE and then pressing Alt+Shift+F1 gives me
information about what dialog RSE itself uses:
org.eclipse.rse.internal.files.ui.wizards.SystemNewFileWizar d
org.eclipse.rse.internal.files.ui.wizards.SystemNewFileWizar dMainPage
HTH,
Martin
Previous Topic:Anonymous FTP access
Next Topic:can't debug remotely
Current Time: Wed May 29 03:51:00 EDT 2013
Powered by FUDForum. Page generated in 0.01474 seconds
