| Unable to view directory structure in FTP [message #534633] |
Wed, 19 May 2010 12:54  |
Stuart Maher Messages: 2 Registered: May 2010 |
Junior Member |
Hi There,
I'm using RSE to do a ftp connection to a remote Linux server. It connects, however will not show the directory structure. The same operation works with CuteFTP. Here is some log outputs.
This is a succcessfull connection from CuteFTP which will result in a listing of 3 directories, cgi-bin, conf and httpdocs:
*** CuteFTP 6.0 - build Nov 30 2004 ***
STATUS:> Getting listing ""...
STATUS:> Resolving host name ftp.******.com...
STATUS:> Host name ftp.******.com resolved: ip = nn.nnn.nnn.nnn.
STATUS:> Connecting to FTP server ftp.******.com:21 (ip = nn.nnn.nnn.nnn)...
STATUS:> Socket connected. Waiting for welcome message...
220 ProFTPD 1.2.10 Server (ProFTPD) [nn.nnn.nnn.nnn]
STATUS:> Connected. Authenticating...
COMMAND:> USER my_user
331 Password required for my_user.
COMMAND:> PASS *****
230 User my_user logged in.
STATUS:> Login successful.
COMMAND:> PWD
257 "/" is current directory.
STATUS:> Home directory: /
COMMAND:> FEAT
211-Features:
MDTM
REST STREAM
SIZE
211 End
STATUS:> This site supports features.
STATUS:> This site supports SIZE.
STATUS:> This site can resume broken downloads.
COMMAND:> REST 0
350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
COMMAND:> PASV
227 Entering Passive Mode (62,193,234,132,198,213).
COMMAND:> LIST
STATUS:> Connecting FTP data socket nn.nnn.nnn.nnn:50901...
150 Opening ASCII mode data connection for file list
226-Transfer complete.
226 Quotas off
STATUS:> Directory listing completed.
Using FTP only server connection usiing passive set to true (although this makes no difference) and then opening the Files>Root part I get shown a "/" and nothing else, here is the log:
USER my_user
PASS ******
SYST
215 UNIX Type: L8
TYPE I
200 Type set to I
PWD
NOOP
NOOP
200 NOOP command successful
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
Does anyone have anyideas?
[Updated on: Wed, 19 May 2010 12:54] Report message to a moderator
FUDForum. Page generated in 0.02125 seconds
