Home » Eclipse Projects » DSDP - Target Management » RSE connection
RSE connection [message #583392] Sat, 12 June 2010 22:08 Go to next message
Mark  is currently offline Mark
I've just begun with RSE. Just downloaded and installed. I've attempted to make a remote connection to a linux host (from my linux box) using "ssh only".
I can connect to the same remote host using ssh and sshfs from a terminal. However not through rse. RSE does something weird: it changes the name of the host into upper case. I tested the upper case name using ssh in a terminal: it didn't work.(In both cases (RSE and terminal) I got an invalid password.
I'd have to presume that the upper case makes the host name invalid. I can't believe that someone else hasn't tried this and found this to be a problem. If there is another possible source for the error please let me know...
Mark
Re: RSE connection [message #639509 is a reply to message #583392] Tue, 16 November 2010 13:48 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
this is the first time I hear that a host name is case sensitive. Very
weird! Anyways, to work around the issue I'd suggest using an IP Address
instead of the host name.
To find out the IP address, do any of
nslookup your.host.name
ping your.host.name
If you can indeed verify that capitalizing the hostname is the problem,
I'd also appreciate if you could file a bug against Target Management,
with more details about your case:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management
HTH,
Martin
Previous Topic:Eclipse hang up. Suspecting RSE...
Next Topic:Enable compression
Current Time: Thu May 23 17:18:45 EDT 2013
Powered by FUDForum. Page generated in 0.01630 seconds
