Home » Eclipse Projects » Remote Application Platform (RAP) » Using Display.syncExec to access UI thread from an IServiceHandler instance leads to a deadlock
Using Display.syncExec to access UI thread from an IServiceHandler instance leads to a deadlock [message #639138] Mon, 15 November 2010 06:48 Go to next message
Michal Tkacz is currently offline Michal Tkacz
Please take a look at the following snippet. What I'm trying to do here
is access fileNameText widget from an IServiceHandler instance which is
supposed to handle a download process (it is triggered by a browser
link). In this case I cannot use asyncExec. But if I use syncExec the
IServiceHandler thread hangs. Is it an error, or a deadlock I should
expect in this case? Thanks.
public class EntryPoint implements IEntryPoint {
public int createUI() {
final Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new GridLayout(2, false));
new Label(shell, SWT.NONE).setText("File name:");
final Text fileNameText = new Text(shell, SWT.NONE);
fileNameText.setText("file.txt");
fileNameText.setLayoutData(
new GridData(SWT.FILL, SWT.NONE, true, false));
Browser browser = new Browser(shell, SWT.NONE);
browser.setLayoutData(
new GridData(SWT.FILL, SWT.FILL, false, true, 2, 1));
HttpServletRequest request = RWT.getRequest();
browser.setText("<a href=\"" + request.getContextPath()
+ request.getServletPath() + "?" + IServiceHandler.REQUEST_PARAM
+ "=download\">click me<a>");
IServiceManager manager = RWT.getServiceManager();
IServiceHandler handler = new IServiceHandler() {
public void service() throws IOException, ServletException {
display.syncExec(new Runnable() {
public void run() {
String fileName = fileNameText.getText();
byte[] content = "Hello world!".getBytes();
HttpServletResponse response = RWT.getResponse();
response.setContentType("application/octet-stream");
response.setContentLength(content.length);
String contentDisposition = "attachment; filename=\""
+ fileName + "\"";
response.setHeader("Content-Disposition",
contentDisposition);
try {
response.getOutputStream().write(content);
} catch(IOException e1) {
e1.printStackTrace();
manager.registerServiceHandler("download", handler);
shell.pack();
shell.open();
while(!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
return 0;
Re: Using Display.syncExec to access UI thread from an IServiceHandler instance leads to a deadlock [message #639408 is a reply to message #639138] Tue, 16 November 2010 07:47 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf Sternberg
Hi Michal,
Display#syncExec should generally used with care, and calling syncExec
from a separate request seems a bad idea to me. This will block the
calling thread, i.e. the service handler request until the runnable is
processed in the lifecycle of the normal request!
I'd recommend to decouple both requests by storing the fileName in a
synchronized (!) field on modification or focus out, and then access this
field in the service handler instead of accessing the widget itself.
Hope this helps,
Ralf
Ralf Sternberg
Need professional support for RAP and RCP?
http://www.eclipsesource.com/support/
Twitter: http://twitter.com/eclipsesource
Blog: http://www.eclipsesource.com/blogs/
Re: Using Display.syncExec to access UI thread from an IServiceHandler instance leads to a deadlock [message #639472 is a reply to message #639408] Tue, 16 November 2010 11:29 Go to previous messageGo to next message
On 11/16/2010 01:47 PM, Ralf Sternberg wrote:
> Hi Michal,
Do I understand correctly that it will be blocked until another action
in the browser (like clicking on a button, entering text etc.) makes it
send a standard UI request to the server? That would be unfortunate
because what the user does after clicking on a download link is exactly
opposite - he just sits there waiting for a download to begin.
Is there a technical reason why (a)syncExec requests cannot be handled
instantly if UI thread is not busy handling standard UI requests?
That's what I did eventually, thank you.
Michal
> Hope this helps,
> Ralf
Re: Using Display.syncExec to access UI thread from an IServiceHandler instance leads to a deadlock [message #639572 is a reply to message #639472] Tue, 16 November 2010 17:50 Go to previous message
> opposite - he just sits there waiting for a download to begin. Is there
> a technical reason why (a)syncExec requests cannot be handled instantly
syncExec calls will be blocked until the runnable has been processed. The
runnable is being processed in the UIThread. The UIThread can only run
during the processing of a request. Otherwise the client- and server-side
widgets would run out of sync.
Ralf
Ralf Sternberg
Previous Topic:Using UICallback for all Server Operations
Next Topic:Widget's border theming
Current Time: Mon May 20 07:30:09 EDT 2013
Powered by FUDForum. Page generated in 0.01656 seconds
