Home » Eclipse Projects » Web Tools Project (WTP) » Web Services (Can't create a bottom up webservice with the tutorial)
Web Services [message #638409] Thu, 11 November 2010 03:31 Go to next message
Gabi g is currently offline Gabi g
I am using Win XP, Eclipse 3.4 and Axis 1.4.1. I have followed the followinf tutorial and I can make a simple webservice running.
The wsdl file is not created in the projext so web aplication is running on tomcat but not services are available.
I have configured everything as in the tutorial, any help? I have done the example many times Sad
Tutorial:
http://www.eclipse.org/webtools/community/tutorials/BottomUp Axis2WebService/bu_tutorial.html
Thanks in advance
Re: Web Services [message #638693 is a reply to message #638409] Fri, 12 November 2010 03:59 Go to previous messageGo to next message
Does the wizzard creates the WSDL file?
Re: Web Services [message #638831 is a reply to message #638693] Fri, 12 November 2010 12:14 Go to previous messageGo to next message
Atosa Khoddamhazrati is currently offline Atosa Khoddamhazrati
So does publishing the web service fail? Did you refresh your project?
Re: Web Services [message #639077 is a reply to message #638409] Mon, 15 November 2010 03:35 Go to previous message
Many thanks for the answer. It seems it fails to publish the webservice. No WSDL is generated by the wizard.
The contents of the services.xml is:
<service name="Echo" >
<Description>
Please Type your service description here
</Description>
<messageReceivers>
<messageReceiver mep="http://www.w3.org/2004/08/wsdl/in-only" class="org.apache.axis2.rpc.receivers.RPCInOnlyMessageReceiver " />
<messageReceiver mep="http://www.w3.org/2004/08/wsdl/in-out" class="org.apache.axis2.rpc.receivers.RPCMessageReceiver"/ >
</messageReceivers>
<parameter name="ServiceClass" locked="false">Echo</parameter>
</service>
The name of the java class that I want to convert to a webservice is name echo.
I don't know what I am doing wrong?
Thanks Smile
Previous Topic:Context Assistant on JSP Expression Language dot operators
Next Topic:Problem using Eclipse WTP\Tomcat\CXF for web services
Current Time: Sat May 25 04:46:36 EDT 2013
Powered by FUDForum. Page generated in 0.01919 seconds
