Home » Modeling » M2T (model-to-text transformation) » import class java(how to import a java Class into a M2T)
import class java [message #638715] Fri, 12 November 2010 05:28 Go to next message
khalilojmku  is currently offline khalilojmku
No Message Body
Re: import class java [message #638717 is a reply to message #638715] Fri, 12 November 2010 05:30 Go to previous messageGo to next message
khalilojmku wrote on Fri, 12 November 2010 05:28
how can I import a Java Class into a M2T !! please answer me
Re: import class java [message #638748 is a reply to message #638717] Fri, 12 November 2010 08:11 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
Hi, to which (Sub)Framework does you question refer to? Xpand Acceleo?. Can you give some more context what you mean with importing?
~Christian
Re: import class java [message #638775 is a reply to message #638715] Fri, 12 November 2010 09:55 Go to previous messageGo to next message
Please who know haw to import a java Class into an M2T (acceleo3) !it's urgent !!
Re: import class java [message #638776 is a reply to message #638775] Fri, 12 November 2010 10:00 Go to previous messageGo to next message
one more: what do you mean with "import" ???
~Christian
Re: import class java [message #638812 is a reply to message #638715] Fri, 12 November 2010 11:13 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane Begaudeau
If you want to use a Java service in Acceleo 3, you can do something like in this screenshot:
http://img233.imageshack.us/img233/3749/workaround.png
Do not forget to export the package containing your Java class and to use the qualified name of your variable (here java.lang.Double). It is a good practice to create a query for each java service that you want to use like in this screenshot.
You can also find the Acceleo 3 documentation online here and in Eclipse (Help => Help Contents, and look for Acceleo)
Stéphane Bégaudeau, Obeo.
Re: import class java [message #639895 is a reply to message #638812] Thu, 18 November 2010 05:10 Go to previous messageGo to next message
Sorry i'am not exelent in English
what do you mean by export the package ! what i have to do
Re: import class java [message #639897 is a reply to message #638715] Thu, 18 November 2010 05:20 Go to previous messageGo to next message
You can see here a screenshot (the last one) indicating how to export a package (open the manifest file of your project, go to the runtime tab and add the package).
Stephane Begaudeau, Obeo
Re: import class java [message #641233 is a reply to message #639897] Wed, 24 November 2010 10:30 Go to previous message
think you sooo much ! I did it finally thinks again !!
Previous Topic:Where did my console go?
Next Topic:[Acceleo/EMF] Problem in Main.java after refactoring one meta-model into two
Current Time: Fri May 24 07:09:40 EDT 2013
Powered by FUDForum. Page generated in 0.01730 seconds
