| getting error about invalidClassException [message #638678] |
Fri, 12 November 2010 02:40  |
leung Messages: 2 Registered: November 2010 |
Junior Member |
weblogic.kernel.ExecuteThread.run(ExecuteThread.java:178)
Caused by: java.io.InvalidClassException: project.dto.abc; local class incompatible: stream classdesc serialVersionUID = 540111968042279174, local class serialVersionUID = -236686455014385772
what should i do?
[Updated on: Fri, 12 November 2010 02:41] Report message to a moderator
| Re: getting error about invalidClassException [message #638835 is a reply to message #638678] |
Fri, 12 November 2010 12:24  |
Originally posted by: richkulp.us.NOSPAM.ibm.com
You are on the wrong newsgroup. This newsgroup is for announcements
about the Eclipse foundation itself. Not for technical questions.
Your question looks like a general java question which would be a java
forum and not an Eclipse forum.
Rich Kulp
FUDForum. Page generated in 0.01532 seconds
