Home » Language IDEs » Java Development Tools (JDT) » Classpath Build Order Changes (.classpath's build order changes)
Classpath Build Order Changes [message #635471] Tue, 26 October 2010 19:54 Go to next message
Missing name Mising name is currently offline Missing name Mising name
I am using Eclipse3.5 JEE 64 bit on OS X Snow Leopard.
Was wondering how the .classpath file's <classpathentry> tag's order gets changed everytime I run a standard Ant build script.
When I manually change the build path order like this (via Eclipse):
(1) Right click on project in Project Explorer.
(2) A context menu opens up
(3) Go to Build Path
(4) Configure Build Path
(5) Click on the Java Build Path Order and Export Tab
(6) Modified the order to look like this:
myproject/work/src (moved this to the top)
myproject/work/test/unit
myproject/work/impl/src (this is a linked resource which points to a 2nd Eclipse project which is open in Eclipse at the same time)
The myproject/work/impl/src by default is at the first position for the order. Manually moved myproject/work/src to the top (by clicking on the Up button).
When I run my build script, it seems that the .classpath file (which this order is written to behind-the-scenes) is reset to how it was before:
<classpath>
	<classpathentry kind="src" path="impl"/>
	<classpathentry kind="src" path="test/unit/impl"/>
	<classpathentry kind="src" path="work/src"/>
</classpath>
Why is this? Where and when does Eclipse modify the .classpath file? How can it be set so people can change the build order manually through Eclipse but the .classpath's build order never gets reset to its defaults? After setting this and building the project by right mouse clicking on my project (not the impl one) and going to Build Project, the order never gets changed. It only resets when the Ant build script is run.
Thank you for taking the time to read this.
[Updated on: Tue, 26 October 2010 20:12]
Report message to a moderator
Re: Classpath Build Order Changes [message #638520 is a reply to message #635471] Thu, 11 November 2010 09:42 Go to previous message
Dani Megert is currently offline Dani Megert
> on the Up button).
> before:
> <classpath>
> </classpath>
> Why is this?
That's not what I see. For me it works as expected (3.6.1 and 3.7 M3).
Dani
> set to people can change the build order manually through Eclipse but
Previous Topic:Code Snap in Editor Window
Next Topic:Listening to changes in the java model - IJavaElementDelta
Current Time: Thu May 23 12:41:53 EDT 2013
Powered by FUDForum. Page generated in 0.01928 seconds
