| Re: Eclipse RCP app: How to disable specific extenstions? [message #638138 is a reply to message #637019] |
Wed, 10 November 2010 02:25  |
Originally posted by: christian.buergi.post.ch
Am 03.11.2010 20:18, schrieb Marco Lopes:
> I'm using Eclipse HELIOS to code a Rich Client app. After the LAST
> Helios Update, the following entries are added automatically to my APP
> "PERSPECTIVES MENU": "Java, Java Browsing, Java Type Hierarchy, Debug,
> Team Synchronizing". I need to get rid of them.
> i'm using the extension point="org.eclipse.ui.activities" to disable
> unwanted extensions (like the editor and search options that appear on
> the coolbar)
> I managed to get rid of "Debug" by adding "org.eclipse.debug.ui.*" and
> "Team Synchronizing". by adding "org.eclipse.team.*"
> This is my actual config:
> <extension point="org.eclipse.ui.activities">
> <activity id="rcpcolibri.disablextensions" name="Hidden activities"/>
> <activityPatternBinding activityId="rcpcolibri.disablextensions"
> pattern="org.eclipse.debug.ui.*"/>
> pattern="org.eclipse.search.*"/>
> pattern="org.eclipse.ui.editors.*"/>
> pattern="org.eclipse.ui.externaltools.*"/>
> pattern="org.eclipse.team.*"/>
> pattern="com.swtdesigner.*"/>
> </extension>
> What extensions should i disable?
> Is there another way of managing this issue?
> Eclipse should work the other way arround: we shoud ADD what we need,
> and not have everything thrown in by eclipse...
> thanks.
In fact there IS another way in Eclipse RCP managing plugins by ADDING
them. Create a target platform where you can actually define which
features will be in your final product. Not having any IDE components in
your TP should remove those perspectives since they won't be packed in
your application.
Christian
FUDForum. Page generated in 0.01652 seconds
