Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Problems with Real division
[Acceleo] Problems with Real division [message #637869] Tue, 09 November 2010 03:52 Go to next message
miguel  is currently offline miguel
I'm trying to evaluate a very simple expression involving Real data and division operator "/". Althought Acceleo environment doesn't detect any syntax problem, the result is not what I expected ...
expression is like :
"[3.3 / 2.1/]"
and the result is something like :
"org.eclipse.emf.ecore.impl.DynamicEObjectImpl@7a4489 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@129b0e1 (name: OclInvalid_Class) (instanceClassName: null) (abstract: false, interface: false))"
when I try another operator like plus, minus or multiplication, the result is as expected.
must I escape the division operator somehow or must I use a different expression?
Any help is wellcome.
Thanks in advance
Re: [Acceleo] Problems with Real division [message #637963 is a reply to message #637869] Tue, 09 November 2010 08:50 Go to previous message
Stephane Begaudeau is currently offline Stephane Begaudeau
Hi Miguel,
There seems to be a problem with the serialization of "/" in xml. It is replaced by "%2F" (the symbol for "/" in xml) but it shouldn't because in our case EMF can handle the deserialization of the "/" and when EMF tries to deserialize "%2F" we don't succeed in matching this to the "/" operator. I've raised a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=329779) to correct this problem. It should be fixed in Acceleo 3.1 M4 or M5 and in Acceleo 3.0.2.
Thanks for reporting this problem.
In the mean time, if you need this operator, you can work around this problem by using a java service, like this:
http://img233.imageshack.us/img233/3749/workaround.png
Stéphane Bégaudeau, Obeo.
Previous Topic:OpenArchitectureWare tutorial 4.3.1
Next Topic:[acceleo] How can I generate code automatically as a dependency on the target project?
Current Time: Mon May 20 01:20:49 EDT 2013
Powered by FUDForum. Page generated in 0.02436 seconds
