| Action listener context menu [message #637257] |
Thu, 04 November 2010 14:10 |
Christian Doerner Messages: 3 Registered: July 2010 |
Junior Member |
I'm trying to achieve the following. I added command listeners to Eclipse's global copy, cut, and paste commands because I have to execute some code in addition to these commands.
My problem is that I don't get the events that are thrown by the JavaScript editor when I use copy, cut, or paste from the context menu. I understand that there is a difference between commands and actions in Eclipse, but I did not find a solution to capture the action events.
Does anyone have a solution that may work here?
Thank you for your help,
Christian
FUDForum. Page generated in 0.01429 seconds
