Home » Eclipse Projects » Platform - User Assistance (UA) » Nullpointer while searching
Nullpointer while searching [message #635392] Tue, 26 October 2010 12:12 Go to next message
Matthias is currently offline Matthias
Member
searching from my local machine with locally hostet infocenter on tomcat works.
The problem is, when I try to search from an rcp app on another computer I get the following error:
Während "Lokale Hilfe" ist ein interner Fehler aufgetreten.
 at org.eclipse.help.internal.util.URLCoder.encode(URLCoder.java:20)
 at org.eclipse.help.internal.search.SearchResults.addHits(SearchResults.java:51)
 at org.eclipse.help.internal.search.SearchManager$BufferedSearchHitCollector.flush(SearchManager.java:183)
 at org.eclipse.help.internal.search.SearchManager.searchLocalAndRemote(SearchManager.java:122)
 at org.eclipse.help.internal.search.SearchManager.search(SearchManager.java:78)
 at org.eclipse.help.internal.search.federated.LocalHelp.run(LocalHelp.java:54)
 at org.eclipse.help.internal.search.federated.FederatedSearchJob.run(FederatedSearchJob.java:38)
Everything else works fine, even the dynamic search function...
Hope someone can help.. Thanks in advance!
Re: Nullpointer while searching [message #635998 is a reply to message #635392] Thu, 28 October 2010 17:35 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris Goldthorpe
Are you seeing the error on the client side or on the server side? This problem is not familiar to me.
Re: Nullpointer while searching [message #636635 is a reply to message #635392] Tue, 02 November 2010 06:05 Go to previous messageGo to next message
Member
The problem is on the client side. Very strange problem..
Re: Nullpointer while searching [message #637058 is a reply to message #636635] Wed, 03 November 2010 19:41 Go to previous messageGo to next message
Can you file a bug report and include the stack trace. It seems that it would be easy to fix - we need to handle the case where highlightTerms is null, I don't understand though why this has not been reported before if there is a path through the code which allows highlightTerms to be null.
Re: Nullpointer while searching [message #637218 is a reply to message #635392] Thu, 04 November 2010 11:55 Go to previous message
Member
I've filed a bug report! Thank you for your help!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=329448
Previous Topic:Anyone have experience with PDF generation from Eclipse Help?
Next Topic:Help Contents empty
Current Time: Thu May 23 02:44:38 EDT 2013
Powered by FUDForum. Page generated in 0.01626 seconds
