Home » Modeling » MOFScript » Feature not found
Feature not found [message #634071] Wed, 20 October 2010 09:02 Go to next message
Torbjørn Knutsen is currently offline Torbjørn Knutsen
I am trying to transform a relational database model to text, but i get an error message when trying to load a model. I have set the NS uri of the metamodel, and used this as input to the transformation. The error message i get is:
## Loading source model - out.xmi... #Error in source model loading: Feature 'typeenum' not found.
Execution Error: org.eclipse.mofscript.runtime.MofScriptExecutionException: Missing Source Models.
I find this weird, since the feature is defined in the metamodel, like this:
<eClassifiers xsi:type="ecore:EClass" name="Table">
<eStructuralFeatures xsi:type="ecore:EReference" name="typeenum" lowerBound="1"
eType="#//TypeEnum" containment="true"/>
</eClassifiers>
So when the input file says:
<table name="UserRole" pkey="//@table.8/@cols.0">
<cols name="uuid" type="Integer"/>
<cols name="Description" type="String"/>
<typeenum>
<enumEntry enumString="UserRole"/>
</typeenum>
It should work?
Is it something that i'm missing here?
- Torbjørn
Re: Feature not found [message #635454 is a reply to message #634071] Tue, 26 October 2010 16:32 Go to previous messageGo to next message
Gøran K. Olsen is currently offline Gøran K. Olsen
Hello Tobj
Re: Feature not found [message #637200 is a reply to message #634071] Thu, 04 November 2010 10:50 Go to previous message
Somehow regenerating the model with another transformation, and copying the output to the input folder of the transformation i'm working on worked. They showed now difference when using diff on the one that works, and the one that don't. Remains quite the mystery to me..
Previous Topic:Subpackages URI problem
Next Topic:Problem with creating instances
Current Time: Sat May 25 20:00:38 EDT 2013
Powered by FUDForum. Page generated in 0.01680 seconds
