| Problem updating Bugzilla repository [message #63456] |
Sun, 14 December 2008 10:38  |
Jonathan Gossage Messages: 42 Registered: July 2009 |
Member |
I am using Eclipse 3.4.1 (Ganymede) with Mylyn 3.0.3. I am accessing my
own Bugzilla repository where Bugzilla is at 3.22.
Bugzilla is configured with usermatchmode=off.
If I use Mylyn to add a comment to a Bugzilla entry, when I submit the
update back to Bugzilla I get the following error.
Bugzilla was unable to make any match at all for one or more of the names
and/or email addresses you entered on the previous page.
Please go back and try other names or email addresses.
Assignee:
jgossage did not match anything
The actual name stored in the Bugzilla entry was jgossage@gossage.ca so it
appears that everything after the @ is being stripped off when the entry
is returned to Bugzilla.
Any suggestions as to what I can do to fix or workaround this problem.
| Re: Problem updating Bugzilla repository [message #63704 is a reply to message #63525] |
Thu, 01 January 2009 16:21  |
Frank Becker Messages: 64 Registered: July 2009 |
Member |
Jonathan Gossage <jgossage@magma.ca> wrote:
> I am using the default Bugzilla values for emailregexp and emailsuffix.
> emailregexp is "^[\w\.\+\-=]+@[\w\.\-]+\.[\w\-]+$" and emailsuffix is
> blank. The Bugzilla parameters page claims the this will match a complete
> email address.
> I can find no reference to local user enabled in the Mylyn preferences.
This is in "Task Repositories" Properties and there in the "Additional
Settings" the first item
Frank
| Re: Problem updating Bugzilla repository [message #595472 is a reply to message #63456] |
Mon, 15 December 2008 16:26  |
Member |
For me this looks like you have not matching setting between
- Mylyn addition settings "local user enabled"
and
- Bugzilla ../editparams.cgi?section=auth parm emailregexp and emailsuffix
What are your values?
> Assignee:
| Re: Problem updating Bugzilla repository [message #595481 is a reply to message #63504] |
Mon, 15 December 2008 17:16  |
Member |
email address.
> - Mylyn addition settings "local user enabled" and
> emailsuffix
>> names and/or email addresses you entered on the previous page. Please
>> go back and try other names or email addresses. Assignee:
>> it appears that everything after the @ is being stripped off when the
>> entry is returned to Bugzilla.
| Re: Problem updating Bugzilla repository [message #595541 is a reply to message #63525] |
Member |
> email address.
Frank
FUDForum. Page generated in 0.03685 seconds
