| Dynamically creating Parts (updated from the E4/Snippets) / Passing around IEclipseContext [message #636111] |
Fri, 29 October 2010 06:57  |
Ned Twigg Messages: 3 Registered: October 2010 |
Junior Member |
First off, I'm a huge fan of SWT and JFace, but until now I had shied away from Eclipse RCP because I thought it made component testing too hard. Dependency injection on POJOs has totally fixed that for me, and I'm really excited to bring Eclipse 4 into my work. Really looking forward to the first 4 book.
I have a very simple Application.e4xmi, which has only the following insertions:
-an Addon implemented by MyAddon
-a Toolbar button whose Handler is implemented by OpenHandler
-a Trimmed Window whose only Control is a PartStack whose ID is "partstack"
I am trying to programmatically open a new Part in the PartStack every time the open button is pressed. I have it working, but I know that I am misusing parts of the API.
First off, I was having problems passing IEclipseContext around. To fix this, I created MyAddon, whose sole purpose is to get a static reference to the top level IEclipseContext. I know I should inject the IEclipseContext where it is used, but in more complex stuff that I have tried I have found myself passing the IEclipseContext all over the place, so I made this instead. Is this passable, or a terrible mistake?
public class MyAddon {
@Inject
private IEclipseContext context;
@PostConstruct
void establishStaticContext() {
staticContext = context;
private static IEclipseContext staticContext;
public static IEclipseContext getContext(){
return staticContext;
Then, in my OpenHandler, I do the following:
public class OpenHandler{
@Execute
public void execute(){
IEclipseContext context = MyAddon.getContext();
IPresentationEngine renderer = (IPresentationEngine) context.get(IPresentationEngine.class.getName());
MPart part = MBasicFactory.INSTANCE.createPart();
part.setLabel("New Part");
part.setContributionURI("platform:/plugin/com.twigg.e4test/com.twigg.e4test.TestPart");
//This is what I thought I should do, but it returns null
//MUIElement partStack = (MUIElement) context.get("partstack");
//I know this is not right, but it works...
MApplication app = (MApplication) context.get(MApplication.class.getName());
MUIElement partStack = app.getChildren().get(0).getChildren().get(0);
part.setParent((MElementContainer<MUIElement>) partStack);
renderer.createGui(part);
CTabFolder tabs = (CTabFolder) ((MPartStack) partStack).getWidget();
tabs.setSelection(tabs.getItemCount()-1);
Why can't I find the "partstack" object by asking for it directly from the IEclipseContext? I know the e4 way would be to do something like
@Inject
@Named("partstack")
private MPartStack partStack;
but I'd like to do something more programmatic than that...
Thanks!
-Ned
[Updated on: Fri, 29 October 2010 07:00] Report message to a moderator
| Re: Dynamically creating Parts (updated from the E4/Snippets) / Passing around IEclipseContext [message #636147 is a reply to message #636111] |
Fri, 29 October 2010 09:21   |
Remy Suen Messages: 462 Registered: July 2009 |
| Ned Twigg wrote on Fri, 29 October 2010 06:57 | I am trying to programmatically open a new Part in the PartStack every time the open button is pressed. I have it working, but I know that I am misusing parts of the API.
Ideally, you should be using the EPartService if you want to perform part-related functions.
| Quote: | First off, I was having problems passing IEclipseContext around. To fix this, I created MyAddon, whose sole purpose is to get a static reference to the top level IEclipseContext. I know I should inject the IEclipseContext where it is used, but in more complex stuff that I have tried I have found myself passing the IEclipseContext all over the place, so I made this instead. Is this passable, or a terrible mistake?
Your way would only provide you with some arbitrary context. You may not necessarily have information local to what you actually care about, say, the active part, or the active window.
| Quote: | Why can't I find the "partstack" object by asking for it directly from the IEclipseContext?
Stuff is only in the context if someone actually put something in there. Did someone actually call context.set("partStack", partStack)? I am guessing no.
FUDForum. Page generated in 0.01543 seconds
