Home » Eclipse Projects » Rich Client Platform (RCP) » How to add java project's classpath to a plug-in's classpath?(How to add java project's classpath to a plug-in's classpath?)
How to add java project's classpath to a plug-in's classpath? [message #636242] Fri, 29 October 2010 16:01 Go to next message
Márcio Dantas is currently offline Márcio Dantas
People,
I did a plugin that writes junit test cases from java source code.
By now, I'm starting to use reflection in my code, but the plugin can't find the classes in the java project being tested!
Is there a way to use the selected project classpath in my plug-in? How??
best regards
Re: How to add java project's classpath to a plug-in's classpath? [message #636456 is a reply to message #636242] Mon, 01 November 2010 08:51 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Márcio Dantas wrote:
> People,
No, your plugin can't see stuff from a workspace through reflection, as
it hasn't been loaded into a class loader.
To manipulate a java project in a workspace from your plugin, you need
to use the JDT APIs. Like using AST to create the JUnit classes, etc.
Please have a look at the JDT Plug-in Developers Guide, and see
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. jdt.doc.isv/guide/jdt_api_manip.htm
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to add java project's classpath to a plug-in's classpath? [message #636474 is a reply to message #636456] Mon, 01 November 2010 10:06 Go to previous message
Hi Paul,
thanks a lot for introducing me to JDT.
I find out that many things I implemented was already done there.
A question: does JDT AST parser provide the execution paths of a method?
Previous Topic:Expand the properties popup menu
Next Topic:FormEditor and canLeaveThePage
Current Time: Fri May 24 11:20:40 EDT 2013
Powered by FUDForum. Page generated in 0.01842 seconds
