| View Refresh Problem [message #634833] |
Sun, 24 October 2010 05:25  |
ash Messages: 142 Registered: July 2010 |
View Is not getting refresh when SelectionChange is happening
Scenario it happens for only for the first time later it works fine.
I have RCP App Which contain all application view.
I fetch the data from database. and display in the view.
when the data is added to the table. when i make the selection change my other view shld respond to the change. it will not happen. i need manually select the view.then select the row in the source view. then view will respond.
Note: All four view are displayed in botton in my appluication ...
like application like console,search and poblem view wht we c in eclipse.
in my application responding view is behind the 4 view at the bottom.
can any one wht might be the problem.
if any code changes let me know and sniphet is available let me know
Ashok
FUDForum. Page generated in 0.02023 seconds
