Home » Eclipse Projects » EclipseLink » Trouble converting SQL into JPQL with OUTER JOIN
icon5.gif  Trouble converting SQL into JPQL with OUTER JOIN [message #634733] Fri, 22 October 2010 17:00 Go to next message
Fericit Bostan is currently offline Fericit Bostan
Member
I'm using EclipseLink 2.1.1 on GlassFish 3.0.1. I'm having a hard time converting a SQL query into JPQL. The SQL works as expected. I guess the thing I'm struggling with is that I'm using a JoinTable on one of my objects that is not represented by an entity.
Below you will find my Entities that are involved in the SQL and the working SQL that returns the correct values.
Any help you can provide me with is greatly appreciated. Thank you for your effort.
Organization Entity:
@Entity
@Table(name = "Organization")
public class Organization implements Serializable {
	@Id
	@Column(name = "OrganizationId", nullable = false)
	@GeneratedValue(strategy = GenerationType.IDENTITY)
	private Integer id;
	@Column(name = "Name", nullable = false, length = 128)
	private String name;
	@Column(name = "Level", nullable = false)
	private int level;
	@Column(name = "Alias", nullable = false, length = 50)
	private String alias;
	@JoinTable(name = "OrganizationAncestry",
			joinColumns = {
				@JoinColumn(name = "Ancestor", referencedColumnName = "OrganizationId", nullable = false)
			inverseJoinColumns = {
				@JoinColumn(name = "Descendent", referencedColumnName = "OrganizationId", nullable = false)
	@ManyToMany(fetch = FetchType.EAGER)
	private Collection<Organization> descendents;
	@ManyToMany(mappedBy = "descendents", fetch = FetchType.EAGER)
	private Collection<Organization> ancestors;
DocumentType entity:
@Entity
@Table(name = "DocumentType")
public class DocumentType implements Serializable {
	@Id
  @Column(name = "DocumentTypeID", nullable = false)
  private Integer id;
  @Column(name = "TypeName", nullable = false, length = 40)
  @Column(name = "Alias", nullable = false, length = 40)
  @Column(name = "Description", length = 256)
  private String description;
  @Column(name = "IsActive", nullable = false)
  private boolean active;
	@JoinColumn(name = "OrganizationID", referencedColumnName = "OrganizationID")
	@ManyToOne(fetch = FetchType.LAZY)
	private Organization organization;
My SQL:
SELECT
	t1.*
FROM
    DocumentType AS t1
JOIN
    OrganizationAncestry AS t2
ON
    t1.OrganizationId = t2.Ancestor
JOIN
	Organization AS t3
ON
    t3.OrganizationId = t2.Descendent
LEFT OUTER JOIN (
            OrganizationAncestry AS t4
		JOIN
            Organization AS t5
		ON
            t4.Descendent = t5.OrganizationId
		JOIN
            DocumentType AS t6
		ON
            t5.OrganizationId = t6.OrganizationId
ON
    t2.Ancestor = t4.Ancestor
AND
	t4.Ancestor <> t4.Descendent
AND
	t1.Alias = t6.Alias
WHERE
    t1.IsActive = 1
AND
	t3.Alias = 'IWT'
AND
	t6.Alias IS NULL
[Updated on: Fri, 22 October 2010 18:37]
Report message to a moderator
Re: Trouble converting SQL into JPQL with OUTER JOIN [message #635092 is a reply to message #634733] Mon, 25 October 2010 11:42 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
Your SQL looks very complicate, I'm not sure what you are trying to do. Could you describe your query in English.
Perhaps also include the JPQL you have tried.
The JPQL may be something like:
Select doc from DocumentType doc join dt.descendents org
where doc.active = 1 and org.alias = 'IWT'
James : Wiki : Book : Blog
Re: Trouble converting SQL into JPQL with OUTER JOIN [message #635156 is a reply to message #635092] Mon, 25 October 2010 15:21 Go to previous messageGo to next message
Member
I've implemented a closure table pattern in a few of our applications. It's worked out very well. We use this for an Organization structure to represent different business units within the company. I have the closure tables implemented and an adjacent table (PartyDocumentType) that references the PartyDocumentOrganization table. The intent is that Organizations can have different document types. DocumentTypes can be inherited from the parent Organization but can also be overridden at the child Organization. So the child Organization's DocumentType has priority over the parent.
The SQL statement returns all the DocumentTypes for a given Organization, including those defined in the parent Organizations, but excluding the duplicates found in the parent organizations (if any, based upon the DocumentType's Alias column).
I have entities defined for the Organization and the DocumentType but not the OrganizationAncestry as it is defined as a JoinTable.
I've provided the DDL for my tables, seed data to populate them and a sample SQL statement.
Thank you for the help...
Chris
DDL:
CREATE TABLE [dbo].[PartyDocumentOrganization]  (
    [PartyDocumentOrganizationId]   int IDENTITY(1,1) NOT NULL,
    [Level]                         int NOT NULL,
    [Alias]                         varchar(50) NOT NULL,
    [Name]                          varchar(128) NOT NULL,
    [UUID]                          varchar(36) NOT NULL,
    [WhenCreated]                   datetime NOT NULL CONSTRAINT [DF__PartyDocu__WhenC__26D2223A]  DEFAULT (getdate()),
    [WhenModified]                  datetime NOT NULL CONSTRAINT [DF__PartyDocu__WhenM__27C64673]  DEFAULT (getdate()),
    [ModifiedById]                  varchar(15) NOT NULL CONSTRAINT [DF__PartyDocu__Modif__28BA6AAC]  DEFAULT (suser_sname()),
    [Version]                       int NOT NULL CONSTRAINT [DF__PartyDocu__Versi__29AE8EE5]  DEFAULT ((0)),
    CONSTRAINT [PK__PartyDoc__40493131220D6D1D] PRIMARY KEY([PartyDocumentOrganizationId])
GO
CREATE TABLE [dbo].[PartyDocumentOrganizationAncestry]  (
    [Ancestor]      int NOT NULL,
    [Descendent]    int NOT NULL,
    CONSTRAINT [PK__PartyDoc__D7F327222E734402] PRIMARY KEY([Ancestor],[Descendent])
GO
ALTER TABLE [dbo].[PartyDocumentOrganizationAncestry]
    ADD CONSTRAINT [rgnztnncstrDscndnt]
    FOREIGN KEY([Descendent])
    REFERENCES [dbo].[PartyDocumentOrganization]([PartyDocumentOrganizationId])
    ON DELETE NO ACTION
    ON UPDATE NO ACTION
GO
    ADD CONSTRAINT [rgnztnncestryncstr]
    FOREIGN KEY([Ancestor])
    ON DELETE NO ACTION
    ON UPDATE NO ACTION
GO
CREATE TABLE [dbo].[PartyDocumentType]  (
    [PartyDocumentTypeID]           int IDENTITY(1,1) NOT NULL,
    [TypeName]                      varchar(40) NOT NULL,
    [Description]                   varchar(256) NULL,
    [WhenCreated]                   datetime NOT NULL CONSTRAINT [DF_PartyDocumentType_WhenCreated]  DEFAULT (getdate()),
    [IsActive]                      bit NOT NULL CONSTRAINT [DF_PartyDocumentType_IsActive]  DEFAULT ((1)),
    [PartyDocumentOrganizationID]   int NULL,
    [Version]                       int NOT NULL CONSTRAINT [DF__PartyDocu__Versi__39E4F6AE]  DEFAULT ((0)),
    [Alias]                         nvarchar(225) NOT NULL CONSTRAINT [DF__PartyDocu__Alias__3AD91AE7]  DEFAULT (''),
    CONSTRAINT [PK_PartyDocumentType] PRIMARY KEY([PartyDocumentTypeID])
GO
ALTER TABLE [dbo].[PartyDocumentType]
    ADD CONSTRAINT [fk_artyDocumentType_PartyDocumentOrganizationID]
    FOREIGN KEY([PartyDocumentOrganizationID])
    ON DELETE NO ACTION
    ON UPDATE NO ACTION
GO
Seed Data:
INSERT IGNORE INTO [dbo].[PartyDocumentOrganization]([Level], [Alias], [Name], [UUID])
    VALUES(1,'INTRAXINC','Intrax Inc','137B3E7D-4938-4746-8AB5-4F7EC834F4AB' )
GO
    VALUES(2,'ICD','Intrax Career Development','1B912F25-538F-4CCC-AC46-40AD3D44A866' )
Go
    VALUES(3,'IWT','Intrax Work Travel','D0440813-31C9-450E-903B-39754EB6CD27' )
GO
    VALUES(3,'ICT','Intrax Career Training','F32C35C8-F29A-4B88-AFF9-278D1C96355B' )
GO
INSERT IGNORE INTO [dbo].[PartyDocumentOrganizationAncestry]([Ancestor], [Descendent])
    VALUES(1,1)
GO
    VALUES(1,2)
GO
    VALUES(1,3)
GO
    VALUES(1,4)
GO
    VALUES(2,2)
GO
    VALUES(2,3)
GO
    VALUES(2,4)
GO
    VALUES(3,3)
GO
    VALUES(4,4)
GO
INSERT IGNORE INTO [dbo].[PartyDocumentType]([TypeName], [Description], [PartyDocumentOrganizationID], [Alias])
    VALUES('Participant Eligibility Form','Participant Eligibility Form',3,'ParticipantEligibilityForm')
GO
    VALUES('University Letter','University Letter',3,'UniversityLetter')
GO
    VALUES('University Letter (Translation)','University Letter (Translation)',3,'UniversityLetterTranslation')
GO
    VALUES('Other','Other',3,'Other')
GO
    VALUES('Program Agreement','Program Agreement',3,'ProgramAgreement')
GO
    VALUES('Other','Other',2,'Other')
GO
Re: Trouble converting SQL into JPQL with OUTER JOIN [message #635331 is a reply to message #635156] Tue, 26 October 2010 09:11 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris Delahunt
Unfortunately, the DDL and insert data does not make it easier to distinguish and interpret the SQL and correlate it to the object model being used. In the future I would recommend you simplify the problem down to components.
In this case, it looks like the you have the Organization and DocumentType tables mapped to objects, and a OrganizationAncestry used as a relation table for a self referencing M:M on Organization. Unfortunately, you are trying to access fields in the relationtable and map them to DocumentType which is not apart of the relationship - JPQL is object oriented and does not support this. So this query will have to be done with native SQL.
Best Regards,
Chris
Re: Trouble converting SQL into JPQL with OUTER JOIN [message #635886 is a reply to message #635156] Thu, 28 October 2010 09:44 Go to previous message
Maybe something like:
Select distinct doc from DocumentType doc, Organization org left join org.ancestors ancs
where doc.active = 1 and org.alias = 'IWT' and (doc.organization = org || doc.organization = ancs)
Previous Topic:Possible bug retrieving single Boolean column
Next Topic:connecting an application to two different JNDI datasources
Current Time: Fri May 24 20:29:49 EDT 2013
Powered by FUDForum. Page generated in 0.01699 seconds
