Home » Eclipse Projects » EclipseLink » help with a ORDER BY COUNT (expression builder and reportquery)
icon2.gif  help with a ORDER BY COUNT (expression builder and reportquery) [message #634750] Fri, 22 October 2010 20:34 Go to next message
brad Mising name is currently offline brad Mising name
Hello all, this may be simple but after fumbling around with it for a bit I have to come to you for help. What I am trying to do:
SELECT COUNT(code)
FROM table
GROUP BY code
ORDER BY count DESC
LIMIT 100
So far my code looks like:
Expression expression = new ExpressionBuilder();
ReportQuery rq = new ReportQuery(class, expression);
rq.addGrouping("code");
rq.addCount("code");
rq.addOrdering(expression.get("count").descending());
rq.setMaxRows(100);
executeQuery(rq);
The issue is that eclipselink is complaining there is no such column as "count" and blows up. Any thoughts or tips? Thanks
-Brad
Re: help with a ORDER BY COUNT (expression builder and reportquery) [message #635084 is a reply to message #634750] Mon, 25 October 2010 11:23 Go to previous messageGo to next message
tried adding:
Expression countExpression = new ExpressionBuilder();
countExpression.get("code").count();
rq.addItem("count",countExpression);
to try and get a column with counts but this didn't seem to work. Any advice?
-Brad
Re: help with a ORDER BY COUNT (expression builder and reportquery) [message #635087 is a reply to message #635084] Mon, 25 October 2010 11:32 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
The issue seems to be your orderBy, try,
rq.addOrdering(expression.get("code").count().descending());
rq.setMaxRows(100);
If still having problems please include the error.
You can also always use native SQL.
James : Wiki : Book : Blog
Re: help with a ORDER BY COUNT (expression builder and reportquery) [message #635110 is a reply to message #635087] Mon, 25 October 2010 12:22 Go to previous message
Thank you very much! Your solution worked well.
-Brad
Previous Topic:Eclipselink query optimization problem
Next Topic:Query.setMaxResults(0) seems to fail
Current Time: Sun May 19 00:30:10 EDT 2013
Powered by FUDForum. Page generated in 0.01734 seconds
