Home » Eclipse Projects » Voicetools » java in voicexml
java in voicexml [message #14127] Wed, 31 May 2006 04:03 Go to next message
Eclipse User
Originally posted by: la1.informatik.uni-ulm.de
Hallo very one ,
i want to use java in VoiceXML tool can i do that , for example
?xml version="1.0" encoding="ISO-8859-1"?>
<vxml version="2.0" xmlns="http://www.w3.org/2001/vxml">
<var name="hi" expr="'Hello World!'"/>
<form id="say_hi">
<block>
<prompt><value expr="hi"/></prompt>
<goto next="#say_goodbye"/>
</block>
</form>
<form id="say_goodbye">
<block>
Goodbye!
</block>
somthing in java
to have values from database
</form>
</vxml>
if one can do that Pl. one examlpe
loiy
Re: java in voicexml [message #14163 is a reply to message #14127] Wed, 31 May 2006 20:21 Go to previous messageGo to next message
Mike Greenawalt is currently offline Mike Greenawalt
Member
Sorry, no. VoiceXML scripting and scope and variable semantics is firmly
specified on ECMAScript. See the VoiceXML specification
(http://www.w3.org/TR/voicexml20/#dml5).
You can use the <data> tag or some other construct to interact with a
Java-implemented external application that can deliver results to the
VoiceXML application. But you cannot embed Java code inside the VoiceXML.
-- Mike Greenawalt
"loiy Ababneh" <la1@informatik.uni-ulm.de> wrote in message
news:3fd3e6ed438f8e68150a14751f62f38c$1@www.eclipse.org...
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> somthing in java to have values from database
> </form>
> </vxml>
> loiy
Re: java in voicexml [message #14216 is a reply to message #14163] Tue, 20 June 2006 16:46 Go to previous messageGo to next message
Eclipse User
Originally posted by: paul.rubenstein.glenayre.com
Hi Loiy,
What you are probably looking for is something like a JSP. You will need
a webserver (such as tomcat) to execute the JSP. You can then produce
something like:
<?xml version="1.0" encoding="ISO-8859-1"?>
<form id="say_hi">
<block>
</block>
</form>
<block>
<prompt>
// JAVA Scriptlet
System.out.println("Goodbye!");
</prompt>
</block>
</form>
</vxml>
> -- Mike Greenawalt
Re: java in voicexml [message #17446 is a reply to message #14216] Wed, 07 February 2007 09:36 Go to previous messageGo to next message
Eclipse User
Originally posted by: avtpuser.gmail.com
Hi Paul,
Is there a mechanism to achieve something similar to your response (JSP),
using VTP-GUI?
I am using the VTP Preview build.
"paul rubenstein" <paul.rubenstein@glenayre.com> wrote in message
news:pan.2006.06.20.20.46.03.865345@glenayre.com...
> Hi Loiy,
> something like:
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> <prompt>
> // JAVA Scriptlet
> </prompt>
> </block>
> </form>
> </vxml>
>> -- Mike Greenawalt
Re: java in voicexml [message #574798 is a reply to message #14127] Wed, 31 May 2006 20:21 Go to previous messageGo to next message
Member
-- Mike Greenawalt
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> </form>
> </vxml>
> loiy
Re: java in voicexml [message #574938 is a reply to message #14163] Tue, 20 June 2006 16:46 Go to previous messageGo to next message
Eclipse User
Hi Loiy,
something like:
<form id="say_hi">
<block>
</block>
</form>
<block>
<prompt>
// JAVA Scriptlet
</prompt>
</block>
</form>
</vxml>
> -- Mike Greenawalt
Re: java in voicexml [message #576111 is a reply to message #14216] Wed, 07 February 2007 09:36 Go to previous messageGo to next message
Eclipse User
Hi Paul,
using VTP-GUI?
> Hi Loiy,
> something like:
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> <prompt>
> // JAVA Scriptlet
> </prompt>
> </block>
> </form>
> </vxml>
>> -- Mike Greenawalt
Re: java in voicexml [message #634515 is a reply to message #574798] Fri, 22 October 2010 00:15 Go to previous message
loiy is currently offline loiy
Mike Greenawalt wrote on Wed, 31 May 2006 20:21
-- Mike Greenawalt
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> </form>
> </vxml>
Previous Topic:VTP as a test application with a call?
Next Topic:Play Prompt
Current Time: Sat May 18 21:16:41 EDT 2013
Powered by FUDForum. Page generated in 0.01904 seconds
