Home » Eclipse Projects » EclipseLink » Two-tier application: Turn off entire cache
icon5.gif  Two-tier application: Turn off entire cache [message #634291] Thu, 21 October 2010 03:39 Go to next message
No real name is currently offline No real name
we're using EclipseLink in a two-tier architecture. We've already turned off the second level cache but are still experiencing problems with stale data regarding the find() method.
Is there any way to turn off L1 cache / identity map for those find() queries? At the moment we just do a refresh on the returned object but this just doesn't feel right.
Fabian
Re: Two-tier application: Turn off entire cache [message #634323 is a reply to message #634291] Thu, 21 October 2010 05:30 Go to previous messageGo to next message
Tom Eugelink is currently offline Tom Eugelink
I also use Eclipselink in a fat (Swing) client, with multiple EntityManagerFactories and one EM per window. We configure EL like this to disable all EMF level caching (EM is ok):
lOptions.put(PersistenceUnitProperties.CACHE_SHARED_DEFAULT, "false"); // do not use the shared cache (otherwise refresh will not update from db)
(We use programmatic configuration, but there is a XML equivalent.)
Tom
Re: Two-tier application: Turn off entire cache [message #634448 is a reply to message #634291] Thu, 21 October 2010 14:15 Go to previous message
James Sutherland is currently offline James Sutherland
An EntityManager must manage everything used in it persistence context. To avoid this, you must either create a new EntityManager (such as per transaction) or call clear() on the EntityManager.
EclipseLink also has support for a WEAK EntityManager.
James : Wiki : Book : Blog
Previous Topic:EclipseLink - SQL Server - Unicode?
Next Topic:Standalone use of MOXy
Current Time: Sat May 25 13:26:37 EDT 2013
Powered by FUDForum. Page generated in 0.03049 seconds
