Home » Eclipse Projects » GEF » Drag&Drop Palette elements in a grid
Drag&Drop Palette elements in a grid [message #630353] Fri, 01 October 2010 17:30 Go to next message
Elhamlaoui Mahmoud is currently offline Elhamlaoui MahmoudFriend
Im new with gef and i wonder if there is a way so i can have a grid in my editor in wich i could place some elements from the palette,
Any ideas
thanks
Mahmoud
Re: Drag&Drop Palette elements in a grid [message #630408 is a reply to message #630353] Fri, 01 October 2010 22:57 Go to previous messageGo to next message
rex is currently offline rexFriend
What is the grid you are referring to?
If you are talking about a grid-layer as a background, the GEF already have it included (in either FreeformGraphicalRootEditPart or ScalableRootEditPart). You just need to activate it by setting a flag in your viewer.
in a subclass of GraphicalEditor:
    protected void configureGraphicalViewer () {
        viewer.setProperty (SnapToGrid.PROPERTY_GRID_VISIBLE, Boolean.TRUE);
Re: Drag&Drop Palette elements in a grid [message #630859 is a reply to message #630408] Tue, 05 October 2010 11:20 Go to previous messageGo to next message
HI,
thanks for the reply, yes im talking about a grid layout as a background, i will try your solution
thanks
Mahmoud
Re: Drag&Drop Palette elements in a grid [message #630920 is a reply to message #630859] Tue, 05 October 2010 15:01 Go to previous messageGo to next message
Hi Rex,
ive tried your silution, but what i was expecting is a layoutgrid as container in which i could place element inside their cell Rolling Eyes
is there a way to do so?
Re: Drag&Drop Palette elements in a grid [message #634064 is a reply to message #630920] Wed, 20 October 2010 12:13 Go to previous message
Udo Walker is currently offline Udo WalkerFriend
Member
Am 05.10.2010 17:01, schrieb elhamlaoui:
> Hi Rex,
> container in which i could place element inside their cell :roll:
Just use org.eclipse.draw2d.GridLayout as your layout manager.
Udo
Previous Topic:GEF EditPartViewer selection
Next Topic:[GEF] under HELIOS
Current Time: Sat Jul 22 09:03:06 GMT 2017
Powered by FUDForum. Page generated in 0.02914 seconds
