Home » Eclipse Projects » Eclipse Platform » Why can't I pull in org.eclipse.ui.workbench to my MANIFEST file?
Why can't I pull in org.eclipse.ui.workbench to my MANIFEST file? [message #633949] Wed, 20 October 2010 01:41 Go to next message
Alex Le is currently offline Alex LeFriend
Upgraded to Eclipse 3.5.2, my plug-ins fail to compile because the
Activator.java class extends the org.eclipse.ui.plugin.AbstractUIPlugin
class, which is in the org.eclipse.ui.workbench plug-in. My own plug-in
never needed to pull in the org.eclipse.ui.workbench plug-in, which is
shown in the "Plug-ins" view of the PDE perspective. My Activator.java
class only imports org.eclipse.ui.plugin.AbstractUIPlugin class.
1. Is this a big change in Eclipse 3.5.2? I have to pull in the
org.eclipse.ui.workbench plug-in, as a dependency, into my own plug-in's
MANIFEST now?
2. As mentioned I see org.eclipse.ui.workbench plug-in the "Plug-ins"
view of the PDE perspective, but I can't add it to the MANIFEST.
Please advise.
Re: Why can't I pull in org.eclipse.ui.workbench to my MANIFEST file? [message #633964 is a reply to message #633949] Wed, 20 October 2010 05:40 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
> MANIFEST now?
You should be adding org.eclipse.ui plugin as your dependency - not the
workbench one.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Why can't I pull in org.eclipse.ui.workbench to my MANIFEST file? [message #634183 is a reply to message #633964] Wed, 20 October 2010 17:14 Go to previous messageGo to next message
>> MANIFEST now?
> workbench one.
That's currently what I have, and my plug-in fails to compile due to
unresolved org.eclipse.ui.plugin.AbstractUIPlugin class.
Re: Why can't I pull in org.eclipse.ui.workbench to my MANIFEST file? [message #634236 is a reply to message #634183] Wed, 20 October 2010 21:30 Go to previous message
>>> MANIFEST now?
>> workbench one.
eclipse -clean or "F5" on the workspace helps! :-)
Previous Topic:IntroPart/ configExtension & the debugging thereof
Next Topic:Cut and Paste Keys in Dialog
Current Time: Sat Jul 22 09:21:37 GMT 2017
Powered by FUDForum. Page generated in 0.03593 seconds
