Home » Modeling » Compare » Registering compare
Registering compare [message #633901] Tue, 19 October 2010 14:11 Go to next message
Miles Parker is currently offline Miles Parker
In hosted Eclipse Runtime I can't seem to get compare to work for my own models -- I've registered them under content types. Any ideas about what might be going wrong?
Also, does it make sense to register these programmatically or through extension point?
thanks,
Miles
Re: Registering compare [message #696260 is a reply to message #633901] Wed, 13 July 2011 11:19 Go to previous message
Cedric Brun is currently offline Cedric Brun
Hi Miles. I realize that's a pretty late answer but I just came upon this newsgroup, EMF compare is using the EMF one (and used to use the EMFT one).
For the record, yes you should either extend the EMF Compare content type directly and then the platform should call EMF compare, or specify the compare merger with your own content type like this :
<extension
point="org.eclipse.compare.contentMergeViewers">
<viewer
class="org.eclipse.emf.compare.ui.viewer.content.ParameterizedContentMergeViewerCreator"
id="org.eclipse.emf.compare.ui.contentmergeviewer.ModelContentMergeViewer"/>
<contentTypeBinding
contentMergeViewerId="org.eclipse.emf.compare.ui.contentmergeviewer.ModelContentMergeViewer"
contentTypeId="org.eclipse.emf.compare.ui.contenttype.ModelContentType"/>
<contentTypeBinding
contentTypeId="org.eclipse.emf.ecore"/>
<contentTypeBinding
contentTypeId="org.eclipse.emf.ecore.xmi">
</contentTypeBinding>
</extension>
<extension
point="org.eclipse.compare.structureMergeViewers">
<viewer
class="org.eclipse.emf.compare.ui.viewer.structure.ParameterizedStructureMergeViewerCreator"
extensions="*"
id="org.eclipse.emf.compare.ui.structuremergeviewer.ModelStructureMergeViewer"/>
<contentTypeBinding
structureMergeViewerId="org.eclipse.emf.compare.ui.structuremergeviewer.ModelStructureMergeViewer"
<contentTypeBinding
<contentTypeBinding
structureMergeViewerId="org.eclipse.emf.compare.ui.structuremergeviewer.ModelStructureMergeViewer">
</extension>
Previous Topic:Functional IDs and other customisations
Next Topic:[EMF Compare] [Compare] Extension point for IPAF registration
Current Time: Sat May 25 23:23:19 EDT 2013
Powered by FUDForum. Page generated in 0.01508 seconds
